HT1250LS+ scan issue
jtsmith82391
Hello everyone, I have a Motorola HT1250LS+ Model #AAH25RDH9DP5AN.
I'm having an issue while scanning, it won't pick any transmissions up while the scan option is enabled. but when I turn scan off it will pick-up on whichever channel is selected. I am familiar with the CPS I'm just unsure what needs changed to correct this. any and all help is appreciated. Thanks in advance.
svfd17
Spring Valley NY
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 4.0.4; en-us; C5170 Build/IML77) AppleWebKit/534.30 (KHTML, like Gecko) Version/4.0 Mobile Safari/534.30)
Check and make sure all the channels you want are added to the scan list.
jtsmith82391
well that's what I first thought, so I did that last night, everything is in the correct scan list and everything is in the correct personality. I'm sure its just a box that been checked or unchecked, just not sure which one and I don't want to go around clicking stuff because that'll just make things worse.
also its only this way with trunking, and not conventional.
svfd17
Spring Valley NY
OK, I see, how many ltr systems do you have programmed?
svfd17
Spring Valley NY
OK so you have one system programmed, you are able to hear traffic when it's not scanning, and once you hit scan you hear nothing. And you have the system assigned to a scan list?
svfd17
Spring Valley NY
Check your pm's
