TRX-1: Hung-up On Updating
TexScan780D
My TRX-1 is hung-up after I tried to update the scanner. The display looks like the below and I can not turn the scanner off.
uP Boot Ver:F1.3
uP App Ver: None
CPU SW Upgraded:
Error - Turn Off
joannedwards
Washingtonville, ohio 44490
the site is still down headquarters also i tried to update my trx1 and it wont shut off it reads up boot ver f13 and cpu sw upgrade waiting for usb can you please help
tvengr
Well Known Member
Baltimore County, MD
Save the attached zipped CPU updater file to your computer and extract. Connect your computer and scanner and run the extracted updater. Your scanner is waiting for the firmware update.
  • CPUUpdater_TRX1_U5.9 (1).zip
tvengr
Well Known Member
Hold down the MENU button while you plug the cable into the scanner. If you go to the Device Manager, you should see the port number displayed. Select that port and see if it works.
usermanual14
You have lost the CPU firmware. You need to download the CPUUpdater. Connect your computer and scanner and run the updater. TRX-1 Scanner Downloads
Tried that. Did not work. Held menu button in also. The scanner WILL NOT turn off anyway anyhow with the data cable in.
usermanual14
I FIXED IT !! Know what I did ? I DID NOT use the data cable from the radio........I used one from a Canon powershot camera. I had 2 trx1 and 2 cables and neither worked. As soon as I pluged the Canon one in it all worked. So......try a different cable.
NJ75
I tried to update today, and now I am receiving "Newer" under all status points.
I'm having the same problem when I'm trying to update my firmware and database for my TRX-1 through EZ Scan. It's stating there's a problem with the "internet connection" and gives me the same "Newer" tag as a status while updating. I'm assuming their servers must be down.
