Hytera MD782 Password
YL3IM
KO26BX
So you have upgraded your HP-series radio to firmware 2.6 and the pw gone right? And what did you do with CPS?
Not myself -- another ham. I don't own a HP series radio yet. He just "Reset Default Data" from the CPS menu.
James21170
Manchester
I'm after some assistance with a lost password on a Hytera PD705LT, I've managed to use Hytera DMR Flashburn to download from the radio the "user-defined" section as I believe that the password can be recovered from this? Can anyone help? Firmware version is V5.05.14.004 Kind regards to all.
James21170
Manchester
Forget this request, I've just found the code now. I knew it would happen. I've spent all day reading about this and as soon as I posted, I left it half an hour and came back to it with a fresher set of eyes and found it. Kind regards to all though and thank you to the forum.
Spikyhercules
Hello W4ADC;
Did you solve your problem? If not, i might help you. You did not mention your firmware version. Anyway there is a tool named flashburn for hytera radios. Unfortunately sharing such tools on this forum is forbidden i think. But you can find it online ;)
1. Download and install flashburn
2. Read "user_defined" data. The result should be approximately 15-16Mb(You need programming cable for this)
3. Send that file to me. I am going to brute force and try to find your pass or reset it.
Are you still around for this and does it work?
Harrypd785
Hello W4ADC;
I also need help if anyone knows anything pd785 v4.5.9.001
josh111
Hull United kingdom
i got conned and purchased 2 hp 605 and 2 pd705 radios . 3 have read and write passwords and one hp blocked . ive tried everything and cannot get around it , i have flashburn but still no look , any one help me , i dont mind paying for your time
mardian
Bontang,indonesia
Hello W4ADC;
Hi, friend
How do I send a file to a friend? I've read it using Flashburn. Is there an email or account that I can contact?
Thank You
0xFF1E071F
Dear friends; I am so busy with my both work life and home life. I might be slow on replying. Please understand. You can send me a dm (dm = start conversation) with the file you get via FB.
radalia
Buenos dias alejoleal90.
Me he permitido enviarle a alejoleal90@hotmail.com mi fichero, ya que tengo el mismo problema pero con un PD605 (no puedo leerlo porque tiene pass de lectura y escritura)
Agracediendo su atencion y sobre todo su tiempo, cualquier ayuda que pueda aportar seria una alegria imagable.
Saludos desde Cadiz - España
A si disposicion.
cgservice
A si disposicion.
What's the problem with your PD605?
