I can't find the ambulance to hospital frequencies
n3obl
ØAES-1024
PA
And also some will depend on the provider. I work in pgh area. I use radio for quick notifications and phone for when i need to speak with physician. I try to keep notifications about 15-30 seconds tops.
scan-pa
RRDB Admin
Lebanon, Pa.
Lebanon County has dedicated TalkGroups for all hospital ED to have conversations with any EMS/Amb.
Sent from my SM-G935V using Tapatalk
millrad
Connecticut
Here in Connecticut, ambulances are required to have UHF radios programmed for 20 ambulance-to-hospital MED channels, duplicated several times with different PL tones for different regions. The channels are all in the 462 MHz range and include the original set of 10 CMED frequencies assigned for EMS in the 1970s. CMED frequencies are controlled by regional comm centers across the state, including Waterbury, Norwalk, Norwich, Tolland, Hartford and Litchfield. Here's the Connecticut statute:
http://www.ct.gov/demhs/lib/demhs/t...m_operational_reqs_for_uhf_medical_radios.pdf
I stil find it strange that some parts of the country don't use MED channels at all.
scooter1968
Spokane, WA
while here in Spokane, WA, they do still use 155.340, in North Idaho, they have gone digital, and are in the 700 MHZ BAND
captaincab
monitoring delco pa with gre psr300 pro2053 and b
In Delaware County they usually have als on board with established protocol. In the rare event it is a bls only rig or they have say a combative patient they will ask fireboard aka dispatch to advise the er or use cell phones. Most of the emergency rooms we routinely go to have a scanner and know what's in bound to them.
millrad
Connecticut
In Connecticut, most hospitals want a radio asessment of patients coming in by ambulance including vital signs, some only want reports on ALS patients. Also, medics speak with E.R physicians by CMED radio when administering certain drugs more often or in larger doses than protcol; whether to call a code after a certain length of time; whether to honor a questionable DNR, whether to allow a diabetic to refuse transport after successful glucose administration; whenever Narcan is used to revive an overdose patient, and docs are always needed for incoming serious trauma calls. These transmissions are all digitally recorded at the RCC and are available for review later by the hospitals, the ambulance companies or, in some cases, the attorneys for patients. I can't believe any hospital gets information from a scanner. Seems really shoddy in this day and age.
captaincab
Considering your reading skills it is hard to believe that great ems system you claim to have. Then again we all know how well that great football team you route for did this year. I never said hospitals get their patient reports from a scanner. They get them from either a recorded hospital phone line from the medics on a cell phone or in some cases a recorded call from the 911 communications center. However protocol is each transport unit announces to fire communications what hospital they are enroute to. And usually the er pays attention and has a bed all ready set up for the arriving unit. Part of what helps us have one of the top ems syems in the country.
ecps92
Taxachusetts
Hmm, I see the Word "Scanner" and know what's in bound to them.
Reading is Fundamental, Comprehension is harder when someone else types info that makes it impossible to even read between the lines
https://brians.wsu.edu/2016/05/26/root-rout-route/
BTW, if you want to begin to pick on People, they ROOT for a Team, they don't ROUTE for them
I will guess you are referencing the NY Giants, that the 1/3 of CT cheer for. :D
jonwienke
More Info Coming Soon!
VA
Posted by someone who appears to be unfamiliar with what can happen when your phone tries to be smarter than you while typing or using voice dictation. The latter is particularly bad at guessing the correct homophone from the context.
ecps92
Taxachusetts
OT - Quite familiar, hence going back and making edits to a post when found [re-read it, after posting] and have disabled auto-correction
We now return us to the topic at hand of Entry Notifications by EMS
garys
Central Texas
About the same time period, I had several incidences where GeoSearch returned error messages. I've found the ULS licensing portion of the FCC to be quirky sometimes. It seems that they like to take it off line randomly on weekends for maintenance.
It's a good source and GeoSearch is very helpful when it's working, but it doesn't work all the time.
GeoSearch is working.
Example Search Criteria: Frequency = 33.7600 MHz, Computed Box Based on Point/Radius: Center = 43° 31' 01.6" N 071° 22' 07.6" W, Radius = 25 Miles, Currently Licensed and Pending Facilities
CommJunkie
FN20jf
How did people from Connecticut get involved in a discussion about EMS ops in Pennsylvania anyway? You do you, Connecticut. Leave us Pennsylvanians to handle our own procedures.
That said, it depends on county. I work in 4 different counties. Two of them have hospital channels on the county trunked radio systems, and two rely on cell phones. You can put the Med 1 through Med 10 channels in your scanner, but you probably won't hear much.
