The radio only puts out milliwatts at 50 and needs an external power amp if I recall correctlyI need to block this thread or its going to have me maxing my credit card. Question. If the lowband VHF exciter an option or is it standard in the radio?
I revel in the title of "Hacker", a crown I willingly wear and by the way, it's festooned with CANBUS 120 ohm terminators.
The exciter is rated at 9mw output from 33 to 48MHz on transmit but it will receive the full 30-50MHz.The radio only puts out milliwatts at 50 and needs an external power amp if I recall correctly
What he asked was "Is the lowband VHF exciter an option or is it standard in the radio?"The exciter is rated at 9mw output from 33 to 48MHz on transmit but it will receive the full 30-50MHz.
Oh, I don't read any previous posts these days, wastes too much time....What he asked was "Is the lowband VHF exciter an option or is it standard in the radio?"
So does an "option" need to be purchased should one find a random radio on ebay?Oh, I don't read any previous posts these days, wastes too much time....
All hardware appears to be in every radio that ships new no matter what options are originally purchased.
You would typically buy a used radio with all the options you would ever need due to the high cost of adding options later. PM me and I can go a little deeper into the subject.So does an "option" need to be purchased should one find a random radio on ebay?
The radio comes with the internal hardware that can can receive low VHF and transmit 9 mW to drive the optional external amplifier module. If you buy a radio you one where the seller lists the options that are turned on. There are threads here listing the optionsSo does an "option" need to be purchased should one find a random radio on ebay?
Good stuff. From the serial terminal you could also type ATZ 15 to exit burnapp and load the ECP mode.So trying to get the thread back on track for my radio adventures.
I had an odd event where the radio #2 became stuck in mobile burn app, message on screen was READY MBAP 13.
Surfing on the forum I found a message that was meant for a mobile 7300
Looks like it's stuck at the burnapp screen.
Per FoilOil on Austech:
To get out:
1. Press the down arrow, display will read M:BAPP. Select to load.
2. Press the Opt1 button, display will read M:ECP. Select to load.
3. Press the Menu button, display will read M:ECP. Confirm? N
4. Press the Opt1 button, display will read M:ECP. Confirm? Y
5. Press the Menu button. The radio should reboot to its normal mode.
Playing around it looks like these are the XG100M steps with the exception of 4 happened so quickly it was a key press of either button 7 or button 8 that provided the "Y" answer and rebooted to normal. If anyone has this documented better please share.
"Select to lo" means select to load
1. Press the left paddle down, display will read M:BAPP. Select to lo
2. Rotate the Channel Select knob one click, display will read M:ECP. Select to lo
4. Press 7 or 8 ; The radio should reboot to its normal mode.
Thanks Shawn!Good stuff. From the serial terminal you could also type ATZ 15 to exit burnapp and load the ECP mode.
Watch EbayI’m considering upgrading to this radio Harris XG-100M. Does anyone have a good source to pick up a used one I have been looking online. Any recommendations would be greatly appreciated. Thanks.
I just picked my'n up on ebay. Just make sure it comes with everything!I’m considering upgrading to this radio Harris XG-100M. Does anyone have a good source to pick up a used one I have been looking online. Any recommendations would be greatly appreciated. Thanks.
I'm going to build a six to ten foot long CANBUS cable with shielded twisted pair. I need the Harris connector pinout and so far have not found it in this forum or in any Harris manual that I've pawed through. Feel free to tell me what page I missed reading!![]()
You beat me to it… I just found my notes… the cable should have a characteristic impedance close to 120ohms. That’s why Harris just used aes/ebu digital audio cable (110ohms). At your proposed distance, it probably won’t matter. Doesn’t need to be super well shielded, but knock yourself out!I realized I could simply measure a CANBUS 120 ohm termination plug and also my prebuilt Harris CANBUS cable. Then I could answer my own questions.
Looking into the female connector that's on the radio and control head you have Pin 2 is ground/shield and 1 & 3 are for serial data. The Harris cable is straight through so pin 1 to 1, 2 to 2 and 3 to 3
Thanks! Since I was in the analytical mode I made a rough mpedence measurement of my twisted pair cable from the garage. Using a 20/80 duty cycle 1 MHz signal and a variable resistor to terminate it, the cable seems to be around 65 Ohms based on watching the rising edge of the signal with a scope. Now it makes sense why we have two 120 ohm terminations, one on the control head and one on the radio since in parallel they are 60 ohms. So now I can move ahead and build a 10 foot cable.You beat me to it… I just found my notes… the cable should have a characteristic impedance close to 120ohms. That’s why Harris just used aes/ebu digital audio cable (110ohms). At your proposed distance, it probably won’t matter. Doesn’t need to be super well shielded, but knock yourself out!
-B
Ya, with 10’, it won’t matter. Characteristic impedance has to do with how the cable is designed. Of course, measuring end to end, the cable should measure ~0 ohms (unless you’re measuring hundreds or thousands of feet), but the cable expects a certain load to maintain the frequency response outlined in its specifications. Not using a cable with the correct characteristic impedance can attenuate a certain range of frequencies, usually manifesting in a rounded square wave on a scope (since the square wave gets it shape from harmonics of the fundamental). But, at such a short distance, you could use old analog telephone cable or analog microphone cable and nobody would be the wiser. The terminations are necessary because the can signal will reflect back down the wire, effectively causing multiple time-delayed signals to be present on the cable at once.Thanks! Since I was in the analytical mode I made a rough mpedence measurement of my twisted pair cable from the garage. Using a 20/80 duty cycle 1 MHz signal and a variable resistor to terminate it, the cable seems to be around 65 Ohms based on watching the rising edge of the signal with a scope. Now it makes sense why we have two 120 ohm terminations, one on the control head and one on the radio since in parallel they are 60 ohms. So now I can move ahead and build a 10 foot cable.
01 Conventional Priority ScanIs there a list of all the possible options and capabilities of this radio?
