You’re missing the point here. I’m not teaching a class on characteristic impedance. It’s a difficult topic to grasp. You’re talking about cable capacitance and inductance and the nitty gritty of cable transmission. I’m talking about practical application of standards like the canbus or aes/ebu digital audio standard. Both are terminated designs, because that creates an effective transmission standard.
Nobody creates a transmission standard and says “this is a great new standard. It’s possible to run this line 10’ using any old wire”. They say instead “I’ve carefully designed this transmission standard to properly transport this specific signal hundreds of feet or more when used with wire that has these characteristics.”
The point of a well designed transmission standard is providing the ability to transmit the desired signal accurately over distance. If you aren’t transmitting at distance, you don’t really need to adhere to the specification to get adequate results! I’m not claiming that the wire makes absolutely no difference electronically, I’m claiming that at 6’-10’, it makes no practical difference.
I guess if you’re sure it will, you should write a letter to Harris for using 110ohm cable for a standard that calls for a 120ohm characteristic impedance. How did it ever work to begin with? What were those engineers thinking? We’re all DOOMED!!!!
-B
Edit: Here’s an explanation. Like I said, we aren’t talking about thing.
Read about Characteristic Impedance (Transmission Lines) in our free Electronics Textbook
www.allaboutcircuits.com
