ICOM F2000D dPMR -> NXDN?
J4KEL
Hi all, have recently purchased some F2000D radios off eBay to add to my current F2000D setup, however I when programming I have found they are dPMR so unable to use the same software to program them. I can make them work together by setting the channels to analogue but obviously won't work together in digital mode. Is there a way in the software to change the dPMR radios to NXDN?
TIA!
12dbsinad
Icom does not make a F2000D. They do make a F2100D NXDN radio, which is the same chassis NXDN/dPMR. I'm willing to bet you bought a F2000 analog only radio.
J4KEL
The F2000D was replaced by the F2100D.
Do you know how to change the F2100D from NXDN to dPMR as the programming software for the F2000D & F2100D is virtually identical, so might be the same way?
12dbsinad
You can't select the operating mode under "model" on the pull down menu? If you go to clone, then information, what does it list for radio info?
