Drafin
<snip for brevity> ...not even weather. Any ideas how to fix this ? thanks for any help.
If the scanner can not receive the WX channels then there is something more wrong than just the programming. The only solution I can suggest (and this may not help) is to reset the scanner to factory default then try to reupload the programming from your software.
To do a full factory reset (from the user's manual):
During the power up sequence press the following keys ---
0, 1
Destructive, clears working memory and
resets all Global settings to factory
defaults. Does not affect V-Scanners.
0, 2
Destructive, resets all Global settings to
factory defaults. Does not affect working
memory or V-Scanners.
0, 5
Destructive, executes EEPROM memory
test, then clears working memory and
I hesitate to give you further information about resetting the radio to factory firmware levels, but if you are so inclined they can be found in the manual as well. But, as with all advice on resetting radios, use these codes and the above that I listed at your own risk. (In other words I am not responsible for the scanner if you "brick" it.)
billkoerner said:<snip for brevity> ...ARC500 is in my computer but I do not know how to use it and the cable Driver is not installed and trying it gives me an error report and said I do not have authorization to go further
Which operating system are you using on your computer? If we can get your cable working I may be able to help you out on the trunking table entry.
First select the trunked system from the left hand column labeled Object Browser -> Trunk System Objects -> Trunk Systems. Once you do this it will list all the trunked systems in your scanner. Find the one that you need to change the trunking table on and go to the right to the column marked "T-Tables" and make sure it is marked custom. Directly beside it (marked with the red circle on my graphic below) is where you would enter the custom trunking tables. Enter them as shown in the graphic below and you should be good to go.
But first we gotta get that cable working. I have not tried to enter a custom band plan manually. I guess I should look into that as well.
Draf
ARC500 screenshot
