IFR 1000 Antenna
KQ4VBE
Low Country SC
Heya Folks!
I just picked up an IFR 1000a...
I'm in the midst of getting it back online and one of the glaring things missing is the antenna!
Any thoughts on what I should be using? Or the specs of the original whip??
Thoughts & comments would definitely be appreciated! It's my 1st service monitor.
-dc 73
KevinC
32D2T/957.282
I'm everywhere Focker!
Heya Folks!
-dc 73
Pretty sure it came with one of these...
Which doesn't work for crap if it's on the bench (unless you use a right angle BNC). I vary rarely used an antenna as I was usually hardwired to a radio, but a right angle telescoping whip would probably work just fine.
ramal121
Lots and lots of watts
Calif Whine Country
wa8pyr
Lead Database Admin
Ohio
Neither of my service monitors have their original antennas; I use the telescoping jobs with built-in right angle hinge and they work just fine.
krokus
Southeastern Michigan
IIRC, the IFR came with a simple whip, that was 90 degrees from the front panel, that was approximately 8 inches long. I don't recall of it was the whip that was bent, or a 90 degree BNC mount.
merlin
DN32su
90 degree telescoping whip is what I see at most service shops. Seen a couple rubber duck's too.
prcguy
I stuck a Maldol telescoping right angle whip with all my service monitors but never really used them. Instead I use the multiband scanner ducky that comes with Radio Shack and most scanners and I use that with a BNC right angle adapter. Its resonant on VHF/UHF/800 and obviously works fine for radios on the bench and still picks up local repeaters, etc. How often do you receive on a service monitor outside the usual VHF/UHF/800 bands? Almost never.
