Import Radio Reference Error
qc
San Francisco Bay Area
I noticed I keep getting an error when I try to Import Radio Reference, I get "Invalid User Name or password" confirmed my login information and it works without problems with Butel ARC536PRO any help would be appreciated
Hit_Factor
Saint Joseph, MI
A couple others have reported the same error. Simplifying the password did not work. I have a complex password and it does work, so that idea was just a grab at straws anyway.
In this post there are links for fixing .NET framework and Win updates. Maybe this will help. it certainly won't hurt. V1.31 G2-G5 Firmware Release
  • Like
Reactions: qc
qc
Thank you I just tried this but unfortunately, it didn't fix this
N6ML
Something else you could try - I don't know if it'll help or not...
  1. Terminate PPS
  2. Navigate to %PROGRAMDATA%\Unication (e.g. enter that in Windows Explorer). You should find a folder named "RadioReference". Rename it to something like "RadioReference-broken"
  3. Launch PPS, and click on "Import Radio Reference". It should say "This is your first time...." again. Proceed, and see if it works this time...
qc
  1. Terminate PPS
Firebuff66
CT
Same here I can import but not log in, You can still use it and can do the above trick every time and you will get the newest data base but its a PIA.
JASII
Memory Capacity
I am having the same issue. I paid for the Radio Reference upgrade and can perform Offline updates, but it does not recognize my User Name and Password, even though they are the very same ones that I log into Radio Reference with.
  • Like
Reactions: qc
ME343
ME/NH/VT DB Admin
Farmingdale, ME
If you have ways to find G_Series_PPS_V00-03-16_Beta22 it'll help correct the login issue
