Import Radio Reference Error
N6ML
G_Series_PPS_V00-03-17_Beta10
That's the version that goes with the V1.40 "beta" "scanner" firmware. I haven't seen any updates on that front lately.......
cpohlad
Midlothian, VA
So, I was encountering the same crash on Windows 10. I decided to try running the shortcut as administrator and it seems to work ok now. Might be something you can try.
EMTMFD
Blackstone, Mass
New dropbox for PPS V0.3.16 Beta22 (the one with the fix for the RR login issue):
Same results! The proverbial finger when trying to login! - Even with dumping the programdata rr folder, as well as running as administrator.
Windows 10
Uni1
Unication Representative
DFW Texas
We have identified a change that was made to the RR API. We need a few more logins to test. PM me your Login if you are having issues. You can change your login info after testing is complete.
