- Joined
- Jan 11, 2008
- Messages
- 1,081
- Reaction score
- 44
Hello all,
I am trying to find any information i can about getting a GETC EDACS SCAT shelf to work with a MIII station.
I have scoured the internet for every LBI i can find, but none of them address the actual programming of the MIII unit to talk to the GETC. I have the GETC programmed (I think) correctly, using WinGETC. If i tap a point on the board for TX HSD generation, i get a proper decode in Unitrunker and the site ID changes with re-programming so this leads me to believe it is correctly set up.
The GETC shelf is not keying the MIII station at all, the two don't seem to do anything at all. I have verified the cabling is correct (it is a stock M/A Com harness between the two). All the appropriate signal pins are cabled and going to the right places. Nothing I do will get the GETC to TX on the air.
The extreme lack of documentation on the actual config of the MIII is my biggest issue I think. I have gone thru and set my freq and such to be correct, but under the Function Lists - GETC IN, none of the value there have actions.
Any help at all would be great, other than links to the usual sources for LBI docs
I have a full archive of those and A. they are all very dated and dont refer to the versions of software im using and B. Don't cover the topics I need. If you have any experience with this I would love to chat about it!
Thanks a ton for any help.
