Interested in getting licensed for your own HF frequencies? Step right in!
belvdr
Complexity and points of failure. HF requires ZERO infrastructure whatsoever, not even a satellite. That means that no matter how far apart yapper 1 and yapper 2 are, you only have two devices to troubleshoot. There is a nice simplicity to that.
And the atmosphere. I think that’s where reliability is lost.
Financial traders like it because it's speed of light(-ish) directly between points.
Satellite has a longer delay.
IP networks have a longer delay and varying paths.
When stocks are getting traded quickly, those few milliseconds can add up to a lot of money. A direct point to point connection can be worth a lot.
Pittsboro IN
Fiber has a VF around 66%, similar to RG-58. I read about those high speed trading firms putting in microwave links from the Chicago bored of trade to Wall street to get milliseconds shaved off an internet based VPN. Who da thunk?
Plus all the routing that happens on IP networks. You never know what path your packet will take once it hits the interweb tubes.
AM909
Radio/computer geek
SoCal
Surprisingly, there was even a movie about it: The Hummingbird Project. It didn't do well.
dlwtrunked
TT are you coming to IWCE?
Ross Merlin is giving a talk on NVIS.
I'm in Mesa about 1 week a month if you want to do lunch sometime.
Simplicity? Propagation, solar conditions, etc. might not agree.
riveter
MD
I mean, that's a very very fair point, and I don't discount it.
You and I both know I was speaking in fear of Parkinson's Third Law though, where it intersects technology. An adequate tech spec will know how to add complexity to a system. A GOOD tech spec will know how to remove it. I just hope and pray I can be good enough to not have a complex system failure during my career :oops:.
That said, yeah, there's a lot of math and dice rolling that can go into getting HF to work too, so you got me there :)
dlwtrunked
Actually a little confusing but the "high frequency" in "HF Trading" does not actually stand for "high frequency" as in radio though HF radio is one of the means used. In the trading marked, "high frequency" means fast trading to outbid others. High-frequency trading - Wikipedia
the book did not focus on radio. See also this book about for history of the battle for fast communications for trading (one land owner refusing to let fiber go across his property can kill a optical fiber route for this type of trading as time lost going around it could theoretically lose bids):
Satellite is not even a competitor for this level of low latency (low time delay).
AM909
Radio/computer geek
SoCal
Right – I was commenting on the trading tangent, not using HF to do it. They used fiber and, more importantly, a more direct route.
A microwave path, of course, has a velocity factor close to 1, right? Add some propagation delay in repeaters along the way that HF could eliminate if you could stick to ground-wave. For a long path, an F-layer bounce at nominally 560 miles round-trip is about 3 ms assuming that same VF of 1.
dlwtrunked
That is indeed the reason HF radio is being considered an alternative to microwave--both elimination repeater delays, whether microwave, cable, or fiber, and property issues. Yes, I figured you knew about the HFT meaning but was not sure of others. There have been recent efforts also for more direct microwave with emphasis on time latency.
