Introducing the SDS200
KR7CQ
Phoenix
ProScan does not have a mobile app. I will post a picture or video of my setup later today.
Yes aware of that about Proscan, but I was picturing you using a mobile app to view the PC screen, I probably misunderstood.
I was thinking of something along these lines, which I'm going to be looking into more in advance of my SDS200 arriving.
Chrome Remote Desktop
I would be remote controlling a PC that is remote controlling my networked (via LAN) SDS200, hopefully allowing handheld control / viewing from anywhere...that's been my dream for a while. My "right angled" CAT 6 cable is on the way for tie-in to my switch.
I already own and love Proscan. Would love to see that setup when you have a chance to share, thanks.
mule1075
Washington Pennsylvania
Gotcha I will try and get a picture or video up asap. And just a FYI i am using this to control my sds100 and 785d. I sold my 536hp and have not bought the 200 yet but it still is a better option than the siren app in my opinion.
sparklehorse
Portland, Oregon
yes if use the cable extention will it affect the antenna strength in any way or will it work the same as haveing it hooked into the back of the scanner
The RG58 at Amazon has a little less loss than the RG174 used in the Scannermaster product, but since it's only a 6-feet run of coax the loss with either one would be negligible. You might more than make up for the small amount of loss if you can position your antenna near a window. Then again it all depends on what you're trying to listen to. If all you're trying to monitor is your local p25 system, and you have a very strong signal, then a bit of loss could be helpful. If you're trying to monitor something that's 30 or 40 or more miles away then you should be thinking about an outdoor antenna instead of jerry-rigging something with the stock antenna.
noaim
Milwaukee, WI
Sure hope they do some work on that app. It has so much potential but needs work and with the new models coming out this would be the time to improve it in my view.
I agree the audio works well to me. I would like it to be more robust. I did not have issues using the app on iOS but have heard that android currently has issues. I use it while I’m out and about using vpn. It’s a start that I wish they would revisit
Sent from my iPhone
ArtU
Ah Oh, anyone else having a weird LCD screen display?
In the last hour it has developed B&W vertical lines that seem to scan across the Color Letters leaving them with black and white streaks in them when you look at it close. From 3 feet away it looks like fluorescent light flicker distortion, but none of those lights are in the room. I even turned off the lights, and repositioned the scanner in my hand and walked around to make sure it was not getting RFI from something but all my other stuff is off right now.
Its like I am seeing a horizontal refresh of the screen on a raster display, but these are supposed to be pixels?
I put it on DC power to make sure it was not bad 60 cycle hash from the power supply diode or something going bad and its still the same.
I'll have to find a place to post the video, this server wont hold the 4M file I made short for just a few seconds.
Art
ArtU
Ok, found a Youtube account;
Yes this is not camera artifacts, it really looks like that with the Human Eye, maybe worse. It is like seeing a vertical line at a Horizontal Refresh rate thru the Pixels. Move to 5 secs and at 6 secs you will see a line of data pixels flash at the far right side of the LCD screen. Started the 5th day after I got it. Yes it has been moved to other spots and carried around. Both on DC and AC power. It gets worse and a little better and cycles like that. Seems to cycle better/worse in timing to certain scanning, maybe CPU interference from itself. Look at around 23-24 seconds when it is receiving and you can see the color change off the Red System Pixels have a white/blue simmer run thru them in a line.
The stronger the backlight, the more it is noticeable.
caldwest
Charleston, SC
My unit had the same problem except the line ran along the bottom of the screen below the SYSTEM DEPT CHANNEL text. At first it was almost constant when I had the dimmers at 100%, 70%, and 50%. I was advised by a forum member to reduce the dimmer percentages so I opted for 70, 50 and 30. After doing that a few days ago, it almost stopped the problem all together. I have not seen the line at all in the past two days.
ArtU
Thank You Caldwest. Today I noticed the same thing, however where its running in my shack I need the back light at 70% or greater. IN any case this is not normal at all. If its not happening to everyone of them, I am going to demand a new one to replace it, I've only had it now 6 days. If its happening to everyone of them, then they will need to recall it. You don't pay this kind of money for a nice screen, which is 50% of the reason I spent $700, to have it act like a 20 year old ICOM screen when its new.
03msc
RF is RF
The Natural State
I'm sure @UPMan / @UnidenSupport are looking into it. Of course, they probably need reports directly to support from users experiencing the issues.
However, it would be good of them to acknowledge that they are looking into it and/or collecting data/reports from users. I'm sure something like serial number + what exactly is being experienced + what troubleshooting has already been done would be helpful to them.
http://support.uniden.com
ArtU
I have full details on the screen issue in my posts I linked to.
caldwest
Charleston, SC
I run my unit with a high dimmer of 70% and it seems to have caused the flickering to stop. I certainly agree that the flickering line is not normal . . . although lowering a setting from 100% to 70% makes the flicker go away, that only 'treats' the problem, it does not 'cure' what is causing the problem.
highstar
Byng, OK
I have a problem that I can't figure out. Turned my scanner on yesterday and it says "SD card access error". Sentinal will not connect to my scanner. I tried 2 other cards and go through the "clear user data" and re right to the card. As soon as I unmount from my computer the scanner says error, need to run "clear user data". It's just an endless cycle. Reformatted original SD card and 2 other ones and repeated the steps over and over. Uniden wants me to return my SDS200 for repairs but was hoping @UPMan or @UnidenSupport would have an idea or an easy fix without having to return it. Thanks in advance for any advice.
escortz28
Powell, Ohio
Hi. Do you have the capability to prepare the microSDHC memory card directly with your PC, i.e. your PC has a memory card reader either built-in or via a USB peripheral memory card reader? If yes, you can prepare the memory card completely outside of the scanner, then insert into scanner, and power on the scanner. lmk if you need the details.
highstar
Byng, OK
Yes I do and tried that with the same result. I'm assuming the original card is bad but did what you said and still getting the same message of use Sentinal clear user data operation to initialize SD card when I insert and turn my scanner on.
03msc
RF is RF
The Natural State
I feel like we need more information...what exactly are you doing? Did it work at first and then stop working? If so, what did you do between when it worked and when it gave the error? I'm not implying you necessarily did anything wrong, just trying to determine if something could have caused it.
highstar
Byng, OK
It worked fine 2 days ago. Just turned it on yesterday and got the SD card error when powered up. After reading as many threads as I could I went through every procedure I knew and could find to fix my situation. I'm just at a loss other than returning it for repairs. I'm open to any advice or suggestions.
escortz28
Powell, Ohio
Hi. I understand how frustrating especially with a new scanner. When you did external from the scanner, did you first format the microSDHC memory card (SDFormatter is a popular tool) prior to use in Sentinel?; in Sentinel make sure Target Model is set to the 200 and then use the Clear User Data (scanner -> Clear User Data, select Display All Drives, and select your microSDHC memory card). After these steps are completed, Write to the Scanner (i.e. the microSDHC card). I recommend writing the entire database and no custom Favorites Lists. I hope you can resolve without having to return the scanner. If you resolve, please share back with the community.
