Is this TK 790 fried?
lrcrabtree
Paige, TX
Acquired a used TK 790. When powered on, all the LEDs light up and nothing else. I've tried pressing the programmable function keys during the power on cycle with no difference. Any ideas on how I might get it to boot and / or what might be wrong?
Larry
Is it dash mount or remote mount?
If dash mount you could try to simply remove the head and make sure the cables are plugged in securely. You will have to remove the top and botttom cover and then remove two screws on each side to access that.
And with remote mount verify all cables are secure. If you have not done so already.
Also if you are not getting the proper voltage to the radio they can do some funky things.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
lrcrabtree
Paige, TX
Is this TK 790 Fried?
I should have articulated a little more about the trouble shooting that I performed. This radio is a high power trunk mount with a remote head kit. I swapped out the remote head for one that I know is working, same result. I tried all the tricks I know to get it to boot into various modes (pressing soft keys while powering on), same result. I have not tried swapping out the cable, that is something I will try next and post the results here, or I guess I could remove the remote head kit and put the control head directly on the radio to eliminate the cable as a source of trouble? Hopefully that's it (I don't know why I didn't think of that sooner).
Larry
lrcrabtree
Paige, TX
Well, I eliminated the remote control head kit and mounted the control head on the radio. That seems to have solved the problem as now I can read and write to the radio. So either the cabling is defective or a connection with the cabling is defective.
Larry
Great! What length cable is it?
lrcrabtree
Paige, TX
The cable is 25 feet. Next I suppose I'll check the continuity of each wire in the cable and see if I can narrow down the issue. It might be worth trying to replace the connectors?
Larry
com501
You could just buy a used cable off Fleabay. Do you really need 25 feet? The stock cables are 17 feet.
Troubleshooting the cable should be easy, put your bare fingers around the cable and slowly draw it through your fingers from end to end. Any anomalies will be apparent. Typical failure is if you find a STIFF spot in the cable, indicating someone ran it under a carpet or mat over the top of a catalytic converter. Floorboards in modern vehicles get hot enough to melt coax and cables where the cat is.
If you get desperate, the Motorola dealer in Reno is also a Kenwood dealer.
