Issue with Astro Spectra CPS
MatthiasTHM
Watertown, SD
I am having problems being able to start up ASTRO Spectra CPS. The error I am getting before the one I have in the screen shot says “The system cannot find the file specified.” How do I fix this so I can run ASTRO Spectra CPS?
MTS2000des
5B2_BEE00 Czar
32 bit Windows. It's not going to run on a 64 bit version. This software is from 2008. Officially supported on Windows NT/2000, XP and Vista. Yes, Vista. It will run on 32 bit versions of Windows 7 and 10.
AK4PY
I've got the very same issue for the XTS3000 and Astro Saber software. OS is Windows XP Service Pack 2. I have not dug into it yet, but I suspect that the final release of the software is looking for something that would be available in SP3, but not 2. This is just my guess. You can find out for sure what file it cannot find in the system logs. I just swapped to another computer for a quick fix.
MatthiasTHM
Watertown, SD
What I did is I took a Windows XP hard drive out of a DoLi printer my grandparents have for parts because the computer was a Windows 10. I was able to start up other programs just fine like ASTRO25 portable and mobile, ARS, AKA, and the tuner.
When I try to start up the Astro Spectra software, the only thing I can get past is the quick menu. After that, it’s throwing me an error message.
Cashanova48
GMRS callsign WSAF780
I'm having the same issues on Windows 11 running Windows XP in a virtual machine. The weird thing is the software would fully open in Windows 10 (but obviously wouldn't read the radio), and still wouldn't work on XP. But after a little while, it won't work on either OS.... it told me it can't find "AstroPort" after looking deeper into things. I don't know how to fix this either. So if you find a solution please let me know.
Thanks,
Cashanova
I was also able to open the tuner, but not the CPS... seems like we've been having the same issue.
RIB, cable, serial port...all can be a factor. OEM RIB/cable or knock off?
I am using what was advertised on Scambay as an OEM motorola cable, with a serial to USB connector that came with it.
marcotor
I ♥ÆS Ø
Sunny SoCal
From looking at your post, did you actually install Astro CPS on the WinXP VM? The error you report is a classic "not found" for the proper executable file. If you just dragged the shortcut or directory into XP, it won't work that way. Also, what program are you using to virtualize Windows XP?
MatthiasTHM
Watertown, SD
In fall, I was able to try again with my Panasonic Toughbook (Windows 7 Ultimate 32-bit) instead. There is no difference in the XP or the Win7, but the reason that I was not able to program it was because of the type of cable I was using. I was using a USB to Serial converter to try to program with a USB port. CPS did not like this, so I used the serial port and plugged it into my Panasonic Toughbook, and it read and wrote the codeplug.
In simple terms, don't use a USB to Serial converter for programming. You need to use a serial cable to program the ASTRO Spectra or any old ASTRO radio such as the XTS 3000.
Cashanova48
Oh... gotcha. I dragged the files over and ran the setup application. Oracle virtual box is what i am currently using. Should I push the files into a usb stick on windows 10 and download the files on the xp virtual machine from that?
Cashanova48
No you should buy an old pc and run the software ribbox and cable like it was designed to be done. At the Radio Shop we still have a Windows 98 Laptop to run old Programs.
Gotcha so a serial to Motorola connecter would not work on a older radio?
