Hello everyone,
I have been experiencing an issue with my AOR DV10 receiver, specifically concerning the NFM reception quality. I have observed a significant degradation in the voice reproduction quality, particularly between the 60MHz and 80MHz frequency range when using the default narrow band filter settings.
Interestingly, I've found that when I switch to a wider filter setting at 100KHz, the signal appears much cleaner. This is a bit puzzling as one would expect the narrower filter setting to provide better signal isolation and hence better quality.
Even more paradoxical is the fact that some signals, which are completely undetectable when using the 12.5KHz filter setting, become faintly audible when I switch to the 100KHz filter. Despite the volume being extremely low, it's quite surprising that these signals can be picked up at all with such a wide filter setting.
Has anyone else experienced a similar problem? And does anyone have any suggestions on how to improve NFM reception quality on the DV10? I'm hoping there might be some kind of workaround or setting adjustment that I haven't thought of yet. Any advice would be greatly appreciated.
Thanks in advance for your time and assistance.
Best regards,
Fafax
Best regards,
Fafax
