Jefferson and Orange county Texas
hiegtx
Dallas, TX
Software doesn't have a setting for multi-site. If I understand right I should set it to check all control channels? There is a setting to stop on first useable control channel, all controll channels or strongest one.
I am currently away from home, so I can’t give you a screenshot. Trying to do this from memory.
You can set the site as stationary, then tell it to check each control channel each time it stops on that system. Just be sure that you have the control channel frequencies for each of the individual sites entered.
TexasMale
Port Neches, Texas
I'm in Orange and get Golden Triangle with exception of Beaumont reliably. Must be on edge of signal strength. But when I pass hwy 62 headed to BMT I can get it, only on my 1040. 1065 will not pick it up at all. 325 works also, but it is a p2. At times signal gets garbled or drops completely. I know BMT is only simulcast system on entire network with 4 tower sites scattered around BMT, one being at water works site along river. What type scanner are you running?
I have uniden 436, sds100, sds200 and unucation G4 and G5 they all get beaumont all the way to baytown. you must have something programed wrong
WB5ITT
Beaumont, TX
None of the SETRRS is PII right now....it IS ALL GTR8000s capable of P1 or P2 but only P1 is in use. if any change happens, encryption would be next before P2...
I work on the stuff........
