Johnson County
WA9JGB
Central Indiana
Here is the deal......Johnson County is testing alot of Digital tg's as we speak. Right now the Dispatch tg's are the ONLY tg's changing from analog to digital. Please if there is anyone in Johnson County that can check the tg's and confirm please advise. I have been told that there may be anywhere form 20-50 new tg's for this county in the Digital mode. My software is not working properly and any help would be greatly appreciated. Listen, Listen, Listen. I like to let my software run while I'm at work, but my Sony VAIO has other things on it's mind right now.
delallen
Greenwood, IN
I thought I noticed Franklin Pd on Greenwood's ADMIN tg over the weekend.
Are you talking about the FD's or all dispatch groups?
I'll certainly help out with this project!
WA9JGB
Central Indiana
It's been confirmed. There will be NEW Digital tg's assigned for ALL Johnson County Fire Depts. I will post a list as soon as I can.
DiGiTaLD
New TGs
That might explain all the new, unidentified talkgroups I've been seeing in Unitrunker, some being affiliated to by known fire/EMS radios.
Here's a list of some I've seen in decimal format. I'm sure I've missed some. I have only monitored traffic on one of them thus far. These may be these new talkgroups, or they may be totally unrelated to this, but they aren't in the database, and have been showing up on the Greenwood site lately.
48288
48064
48304
48320
48400
48368
48032
48528
48544
48416
48048
48000
48464
48016
48208 - Heard it referred to on the air as "Admin 8", possibly Clark Fire Administration
WA9JGB
Central Indiana
48288
48064
48304
48320
48400
48368
48032
48528
48544
48416
48048
48000
48464
48016
That Admin 8 is the Needham (Clark) Fire admin. Good find.
You are correct....These are the new tg's in Jo Co. Keep listening.
delallen
Greenwood, IN
I have not picked up any new tgs.
I did hear Clark FD talking about taking a radio out of a rig.
(don't know if this is related to new radios)
I'm still here and I'll let you know when I hear them...
delallen
Greenwood, IN
I ran ID Tracker on Greenwood's site from 14:00 to 6:00 am Sunday and found these tg's that I can't identify:
535 (sounded like Greenwood Fire)
592
759
7303
7319 (Hendricks Co?)
7687
39776 (testing radios)
I'll try it again tonight.
jerk
jerkville
592
759
7303
7687
Some of those look like they had status bits used...
In other words ID's should be even numbers number not odd, evenly divided by 16
the 39776 one looks correct. 592 is in the database New Whiteland Fire.
AK9R
Staff member
Super Moderator
Central Indiana
delallen said:
7303
7687
As newsalan mentioned, the odd numbers indicate that a status bit was on.
7303 could be 7296 (32 HCP HQ) plus 7.
7319 could be 7312 (32 HCP DISP) plus 7.
7687 could be 7680 (41 FPD DSP) plus 7.
39776 is divisible by 16, so it's a legitimate TG number, but I didn't see it in the database.
delallen
Greenwood, IN
I'm not clear on staus bits.
I checked my settings and I have status bits set to "off"
But you are correct on the first items because they sounded like talk groups I'm use to listening to.
I agree that the last one is a new tg.
Thanks for the tip that legal tg's are divisble by 16.
jerk
jerkville
This for Type II systems, P25 and Type I systems are different. With that said, and the above, it could possibly be multiselect, which would make sense if new or testing.
Type II status bits
Dec ID + # Usage
ID+0 Normal Talkgroup
ID+1 All Talkgroup
ID+2 Emergency
ID+3 Talkgroup patch to another
ID+4 Emergency Patch
ID+5 Emergency multi-group
ID+6 Not assigned
ID+7 Multi-select (initiated by dispatcher)
ID+8 DES Encryption talkgroup
ID+9 DES All Talkgroup
ID+10 DES Emergency
ID+11 DES Talkgroup patch
ID+12 DES Emergency Patch
ID+13 DES Emergency multi-group
ID+14 Not assigned
ID+15 Multi-select DES TG
WA9JGB
Central Indiana
48128 is County Fire FG-1
I submited alot of new tg's, but they haven't shown up yet in the database.
Radios have been installed in Whiteland and Needham fire vehicles. Amity has about 30 new digital radio wt's, but they were sent back for re-programing.
Anyone have anything else?
scannerfreak
Well Known Member
Indiana
That is because they haven't been identified for usage. "Unidentified" or "Unknown User" info is not suppose to be in the database until confirmed usage. As soon as you guys figure out who is using what, we will put them in. For now, please post the unidentified talkgroups here :)
WA9JGB
Central Indiana
scannerfreak said:
That is because they haven't been identified for usage. "Unidentified" or "Unknown User" info is not suppose to be in the database until confirmed usage. As soon as you guys figure out who is using what, we will put them in. For now, please post the unidentified talkgroups here :)[/QUOTE
Will Do... Srobo jump in.
WA9JGB
Central Indiana
New tg's
Please change the database to 48128 for FG-1 not 42128.
48032 FFD-Disp
48416 FFD-EMS
48448 FFD-Ops 21
48464 FFD-Ops 22
48432 FFD-Admin
48000 BFD-Disp
48016 EFD-Disp
48064 GFD-Disp
48208 JCF-ADM 8
Unknown usage tg's Have had several hits over the past 2 weeks.
48048
48080
48096
48112
48144
48176
48192
48224
48240
48256
48272
48288
48304
48320
48336
48352
48368
48400
48496
48512
48528
48544
48560
WA9JGB
Central Indiana
Bargersville Fire Dispatch is now dispatching Trafalgar Fire on there frequency.
154.175
DPL 023
BFD-Ops 3 will be Trafalar Ops after the change.
