I think the 436 would have done that for you.THANKS for the help I returned the BCD436HP and looking for suggestions for a good entry level scanner for Will and Grundy counties in Illinois.
You can still listen to the will Co p25 system has east joliet and surrounding agency's in there and they may respond to joliet mutual aid. Will County (P25) Trunking System, Joliet, Illinois - Scanner FrequenciesTHANKS for the help I returned the BCD436HP and looking for suggestions for a good entry level scanner for Will and Grundy counties in Illinois.
FWIW. Picked up a used BTT P25RX rig last month. Works great for WILL County when in the area.You can still listen to the will Co p25 system has east joliet and surrounding agency's in there and they may respond to joliet mutual aid. Will County (P25) Trunking System, Joliet, Illinois - Scanner Frequencies
I am in the same boat in Saint Charles. ISP Is not encrypted. Fire EMS And the like also are not. I just hooked up a GPS And will start exploring other things to hear. I did the gps mod that is on this site. Temporary connections at first to make sure all was working. This weekend will be solder time. Good luck.The City of Joliet uses the StarCom21 P25 Trunked system. Unfortunately, ALL Joliet talkgroups (even Public Works) are fully encrypted and cannot monitored with any scanner.
Actually, Fire and EMS in Joilet are encrypted too. When I said ALL talkgroups, I meant every single one, even Fire, EMS, and Public Works. There's literally NO agency in the city that's in the clear. Your only options are to monitor ISP, the surrounding cities, and the Will Co P25 system.I am in the same boat in Saint Charles. ISP Is not encrypted. Fire EMS And the like also are not. I just hooked up a GPS And will start exploring other things to hear. I did the gps mod that is on this site. Temporary connections at first to make sure all was working. This weekend will be solder time. Good luck.
Kendall County is probably the best county in Illinois for radio listeners everything is still analog and they have no plans to switch thatWow I thought Kane and DuPage sucked. I need to move to a more open part of the country. LoL.
