K40 used as a scanner antenna
ve3zo
Ontario
Has anyone used a K40 CB antenna for a scanner? A friend of mine has one laying around and thought maybe he could use it......The whip would be cut of course.
Any suggestions?
Chris
VE3CTP
rcvmo
Romulus, Mi.
Becuase of the coil at the bottom, it's probably going to be best tuned for the low-bands, 25-50 MHz. Anything above that will have degraded performance.
RCVMO
bwhite
Carroll County, MD
I use an old RS cb antenna, works well for VHF-Lo, not too bad for VHF-Hi or 800. Certainly better than the duckie (even the high-priced ducks). You may need an adapter to plug into your scanner, about $5 from RS. The price is right, try it before spending real money.
RevGary
Pastor and Chaplain Responder
Just did some quick math using the coil turns to diameter ratio of the K 40 - Since the K40 has a set screw which holds the whip in place, loosen the set screw and remove the original CB whip. Pick up a USED 800 MHZ curly center coil 16 inch whip and install that in the K 40 whip adaptor and secure the set screw. Taking the K 40 loading coil into consideration, this will give you very close to 1/4 wave multiple on low band, 5/8 wave multiple on VHF high band, 1/2 wave multiple on UHF and a full wave multiple on 800.
For the price of an 800 curly center whip, you might be surprised at the operation of this configuration. Just using the K40 as-is is better than nothing, but you can tweak it a bit for better performance by replacing the original whip and relying on the loading coil to extend the operation of the replacement 800 whip.
bwhite
Carroll County, MD
We're assuming he's trying for 800.....perhaps not.
At least now he has options and info no matter what direction he's going in.
