KAS20 AVL internal error
mperez17
Hi, I'm trying to setup the KAS20 AVL to display the GPS on the map.
When I request the GPS report the log displays "internal error". So far I have installed SQL server express, I have installed KAS-20S, I have verified that the database is populated with tables, I have installed the KAS-20C. The repeater (NXR-5800) is connected via Ethernet cable, I have verified that I can ping the repeater. The radios (NX-3320) are configured to send the GPS data when the position changes by 100 meters. Data system personality option is selected in the KPG-D3. Every time the radio sends the GPS data the repeater's TX led lights on, however no information is shown on the map.
Any hint where the problem might be?
kd4efm
EL98 Florida
Do you have the 20 setup for group call?
Do you have the 3k's set to GPS Group or to console ID?
Little more to set up on it. Did you follow the guide for settings on the all?
mperez17
We are following the Basic Operations_EN.pdf guide, unfortunately the example given is for KPG-111D. We are using KPG-D3 and the menus are not the same. We have installed Wireshark network analyzer and have found that there is a SIP invite request sent from the server ip address to the repeater's ip address. The repeater first responds with a 100 trying status code and then with a 488 not acceptable code.
So far we are testing with only one radio. We have two repeaters, repeater number 2 is currently in use by all radios for calling, repeater number 1 is not in use, we want to use it for GPS only, therefore only one radio is configured to use repeater number 2 for calling and repeater number 1 for GPS data.
To console ID, have tried with value 1000 (KAS20C) and value 1001 (KAS20S)
Also tried with group ID and it didn't work.
kd4efm
EL98 Florida
okay, that wireshark tells me you do not have the console in the KPG-110SM or D2 programming.
Is this trunking or conventional?
Only noted you said NXR-5800 in singular form so taking word as conventional setup.
I will wait for your info based on this question.
kpg-d2
110SM
mperez17
Hi, It's conventional. I didn't have the IP console checkbox checked and I have the console information table empty.
You pointed me in the right direction!!
I'll fill in the missing information and try again.
Thank so much for your help.
mperez17
Hi, I have found that the KPG-110sm is for trunking mode, we used it once but our users did not like it, therefore we went back to conventional mode.
In the D2 I have the console ID registered with numbers 1000 and 1001, unfortunately the KAS-20 does not work, it keeps saying "internal error".
kd4efm
EL98 Florida
sounds like the database needs to be gone back over again, it is not populated corretly.
Do a fresh install again please.
