Kenwood & EF Johnson - FPP Mobile Radios
tweiss3
Is it time for Coffee?
Ohio
I have a supply of FPP licenses for the nx line.
+1 buy from Evans
Don't know. I don't use FPP on any of my NX-5000's. That sounds like an Evans sort of question. I suspect that since the FPP is technically only a "federal" feature set, that it will stick where you put it. In other words, the dude poking at the radio is expected to know the rules and do things correctly. If everyone was following FCC rules, FPP wouldn't be available as widely as it is.
I'll answer my own question, now that I am back at home.
That would explain the complaint of quiet audio.
  • Like
Reactions: RRR
jaspence
Michigan
The EFJ5100 HTs had FPP even on the limited keypad model. I have a 2 meter, 800 MHz, and 900 MHz and they all have FPP. Not sure if your needs include an HT, but mine have been very reliable, still work well, and batteries are available.
I'll keep the HT option in-mind, but I was primarily interested in a mobile solution, both for VHF & UHF. Since I've been away from radio in general for +21-years, and I moved to a different part of the state, I need to do a bit of research. My job has me pretty mobile, covering over 5 counties, so I'll have to see what systems are in-place, & go from there. There may be some 800/900 MHz Systems I'd be interested in monitoring, but I just don't have enough information at the moment , to make a decision in that area.
At this point, I'm keeping all options open.
ems55
New Milford
Scanners are nice if you want to listen.
Then just get a separate VHF and UHF radio that meets your needs.
But I'm a guy that still runs a Motorola CDM-1550 in his personal truck. Someday I'll upgrade, but analog fits my needs right now.
Work, however, is a different story.
Yep, I just put my CDM-1550, VHF, in my Sierra 1500. 20 years old and still sounds great !!
