shmget
Not sure. I have the 380-470 split. I'm not licensed for anything above 469, but I could try putting in some receive frequencies and see what happens...
Thank you Mark, I'm glad someone finally got back to me. Thanks for the info. I should be good with the 403-470 split as it'll do ham and local PS I need it for.Slapshot, I know your question is old, but I had a 5300K2 for a while and could only get it down to around 446 or 447 for rx. Anything beyond that and it would whack out pretty badly.
What??? I will not buy it if they will do it as described above. I need DMR in NX5000 listed next to Analog, P25 and NX.Reboot to get into DMR mode?
I was told that DMR will be implemented like P25 etc.. That means, you can just toggle through your channels from analog over nexedge to P25 and DMR in one session.
Yes. Mobiles are pretty good for OOB. I can do RX/TX up to 500 MHz on my NX-5800 (380-470)Just a quick question. Has anyone done any testing with out of band in these radios?.
Well that is some phenominal news!Yes. Mobiles are pretty good for OOB. I can do RX/TX up to 500 MHz on my NX-5800 (380-470)![]()
Looking to do a firmware upgrade to 1.71 on my NX-5700 - In the software I only see a FPRO ICON and not an actual .exe file. Can you use an existing Fpro say from the TK-5720 to conduct the firmware upgrade?
Thank you.
Well this is extremely disappointing...Ok gang, here is what little chatter I am hearing, but understand, it has not been sent to the US yet, they are still working on the code and firmware.
Kenwood DMR for the NX-5000 series, IF you have P25 in the radio, you will have to revoke that license in order to install the DMR feature. Allegedly it is told that the code uses the P25 functions, but shifts the DVSI chip into DMR mode (which is part of the firmware update and coding they are still working on).
Therefore to currently state, if you have P25 in the radio and need DMR also, you allegedly will have
to multi-deck your setup. P25vhf, DMRvhf, other deck
Like I am saying here, word is this is allegedly what will come out during the 3rd quarter of sales
time frame. NOTHING ELSE is being said about it other than what I have been told. I am hoping they will consider the words of others, being able to run P25 or DMR without loosing a mode will make this
platform the best thing on the market. All I can do is wait. All Georgia and California can do is wait for it to come over to them for their R&D and then US release (North America/South America).
I will let you know more when I hear something.
Evans
Evans, do I understand correctly that you could have one UHF deck configured for P25 and a second UHF deck configured for DMR?Therefore to currently state, if you have P25 in the radio and need DMR also, you allegedly will have to multi-deck your setup. P25vhf, DMRvhf, other deck
Correct. The thing is NXDN is standard, p25 or DMR are options.Evans, do I understand correctly that you could have one UHF deck configured for P25 and a second UHF deck configured for DMR?
Does the same situation exist with NXDN? IOW, could you have a VHF deck that is configured for analog/NXDN and a UHF deck that's configured for UHF/DMR?
