Kenwood TK-840 Programming Help
QHaba
Plymouth, MN
So, I bought a Kenwood TK-840(N) off eBay.. not sure at all what the N stands for, but I have downloaded the programming software, and DosBox. I plugged the programming cable into the radio, and plugged the USB into the PC. I changed the COM port from COM4 to COM2, as it only supports 1 and 2. I pressed read from radio with it plugged in, and on, and it says could not connect.. Can anyone help?
If you are wondering what I'm using it for, it's for school. I am making a "base station" at school for a thing we do called bus duty. The name says it all, you call the buses.
I can't even get the darn thing to read, could someone help?
I'll add pictures of it in comments.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Likely you need a serial cable. DOS and USB don’t play easily together.
