Kerrville/Kerr County on LCRA
rattlerbb01
TX/LA Database Admin
Boerne, Texas
So far the following talkgroups have been verified with Broadcastify Calls:
10018 - Kerrville Fire/EMS Response
10021 - Kerrville Fire/EMS Dispatch (patched to VHF with the usual MDC squawk)
If Kerrville PD or city public works are using it, someone would have to park on the Kerrville tower. The above talkgroups only appear for the period of time an ambulance is coming into a San Antonio hospital.
TLR2019
Random Member
Texas Hill Country
I'm not sure if that would be encrypted or not if is.. the KPD main channels are E
And I think Kerr Co So Channel 2 is E
NC5267
San Antonio
Most LE agencies if they are encrypted before getting or jumping on an existing trunked system usually stay Encrypted. So KPD will probably stay E. KCSO will probably need another tower to get better coverage out there.
rattlerbb01
Boerne, Texas
We shall see, it seems Motorola won the bid for the county upgrade since they made the promise to meet Kerr County’s strict coverage requirements. LCRA proposed 6 additional tower sites for the 700 MHz side to cover all of Kerr, and that wasn’t enough to meet the county’s minimum criteria. The terrain there and in neighboring Bandera and Real are very difficult to fully cover. So many deep canyons and ridges but not all are even lightly populated.
boernegang
Boerne,Tx
Has anyone looked for or found what Motorola's solution is??? I have googled it and only found articles in the Kerr paper that you have to be a paying subscriber to read.
boernegang
Boerne,Tx
Was in Kerrville today with the 436hp in search mode. TG 10004 sounds like Kerr County SO, also heard traffic on 10043 with vehicle/DL returns but never caught a unit number to determine what agency it may be. Based on radios ID's these are patches to the VHF system.
TLR2019
Random Member
Texas Hill Country
10043 is a internal Channel for Kerr Co So
And Police to check with Each other
i am Naming Kerr Co Law Exchange
For local agencies warrant check
Of both City and County
you wont here unit id numbers
instead listen for them saying PD to SO
or SO to PD Check (cause their checking for what like you said DL and LPs)
TLR2019
Random Member
Texas Hill Country
I witnessed the channel long ago while observing KerrPD dispatch operations.
Since its Dispatch to Dispatch Comm
i was able to hear a event with Kerr SO
and (KPD) Kerrville FIre.. for what happened this com was used to
replay patient information, (ex. was it a boy or a girl)
(Kerrville fire is dispatched by Kerrville PD)
(Kerrville PD main channels are Enc)
so this is just the city and County
channel to help keep themWorking with each other
NC5267
San Antonio
They just switched to the LCRA system. I'm sure their contract with them has some hefty penalties for early termination. Especially this early. They can use Motorola radios on the system and have GATRRS programmed in for interop if they want.
TLR2019
Random Member
Texas Hill Country
The city of kerrville is added to LCRA.
It would make sense for the sheriff's office to join GATRRS.. since Real, Edward's countries And Uvalde also use this system.
NC5267
San Antonio
Rest of the article is behind a paywall unfortunately. But, the county set aside money less than a year ago after Motorola and LCRA did their presentations. I have only seen the county on the LCRA sites so far.
For interop all they have to do is get permission from surrounding GATRRS users and get there system and channels programmed in and a couple of button hits later they're taking to Real, Edwards, etc... I know Gillespie County did this
rattlerbb01
Boerne, Texas
It’s an odd county to pick a direction for sure:
LCRA: Kendall, Gillespie, city of Kerrville
GATRRS: Real, Edwards
VHF P25 Conventional: Bandera, Kimble
Realistically speaking, the borders with Real and Edwards are sparsely populated, so unless Moto and GATRRS are making this a sweetheart deal to connect the MRG and Western Counties together solidly via Kerr County, then LCRA probably would have been the more logical route.
With that said, I think GATRRS is going to be the dominant player in South and Central Texas going forward. They’ve been repositioning and upgrading sites as well as adding new ones to the area. LCRA is expanding as well, but VHF is just better suited to the hill country and mesquite country.
boernegang
Boerne,Tx
Sounds simple, The Sheriff in Kendall County installed VHF radios in the patrol cars for interop with surrounding counties that still used VHF, one county did not want to allow permission or give them the info to be programmed into those radios. If ego's and "mine, mine, mine" could be removed from the system admins imagine what could be accomplished...
