Key Bridge Collapse
tvengr
Well Known Member
Baltimore County, MD
The Key Bridge in Baltimore harbor has been struck by a cargo ship and collapsed. There were workers on the bridge at the time. Assets from Baltimore County and all of the surrounding counties are responding.
maus92
Eastern Shore
Maryland ship pilots at it - or should we say not at it again. Two major causalities in two years. This could close the port of Baltimore to ship traffic for a period of time until the channel is cleared. Amazon and other companies have extensive warehousing operations at Sparrows Point so they will need to reroute.
maus92
Eastern Shore
Baltimore City Fire Ground 4 is the channel that Anne Arundel units were told to switch to. Not many mutual aid units from AACo responding. FB19 initially, then a Medic unit later to Fort Armistead for staging.
maus92
Eastern Shore
Requesting an ROV from Howard County to report to Baltimore County side of bridge.
rustyhodge
I like to listen
San Francisco
Here's an excerpt from that YT live stream sped up 5x
The ship starts blowing black smoke, and around that time the course appears to change and the lights on the ship go off for about 30 seconds, while it's still turning towards the bridge support... and then crashes into it, and the bridge collapses.
maus92
Eastern Shore
The camera has a zoom lens so motion and course changes could be visually exaggerated. I suppose one could initially conclude that the black smoke indicated an increase in speed and a deliberate turn into the supporting structure. I'm pretty sure the vessel has already be boarded as there are security teams from multiple agencies stationed at the port.
maus92
Eastern Shore
MD Tac 7 on FIRST; not all units have that capability, ugh. Looking for another channel. Switching to MD Tac 6 for aviation units.
maus92
Eastern Shore
Trac
Tracking 5 helos at various altitudes: Trooper 1, BCP, USCG and two news.
rustyhodge
I like to listen
San Francisco
If you go way back in the YT live stream, there are several other ships that come through the bridge before, so you can get an idea for the course they should have been taking.
You can see the course change. BUT that seems to happen after the first power failure. It might have occurred if they were pushing against the current. I'm not sure what the tides were at the time of the accident.
maus92
Eastern Shore
They could very well have suffered a causality prior to striking the support pier - obviously something caused them to steer out of the channel.
At least one crew member aboard was injured, possibly a cut hand. Apparently he was taken off the vessel and the FD command is trying to find out who transported him and to where.
mrusting
I see two blackouts. Soot likely from auto shutdown not a speed-up, as a slow speed diesel engine is still turning, EGE offline so soot blows. Restart and then another blackout - possibly from overloading main bus in conjunction with bow thruster transformer. I can't make out an anchor drop - usually only one is rigged for maneuvering. Can't make out stbd side but no motion on port that I could see. Probably would not have helped.
When Baltimore County Fire first dispatched, they mentioned a steering failure.
Yea a blackout will do that. The restoration of power after the first blackout I suspect lead to a scramble and another blackout as the auxiliary engines probably met bus/power interference from the restarted EGE.
Total guesses but I have seen similar blackout events before. Tragedy. Sorry to see.
EDIT: I went back and looked carefully on full screen and they might well have dropped the port anchor 4 or 5 seconds or so after the first blackout.
mrusting
The restart seems like 35 seconds from the first blackout. That seems fully legit. If the port (or any) anchor was dropped, power then comes back they are pushing the bow thruster full to move to port - against the anchor. We see the stern slide to port just before the collision in the second blackout. It (anchor) hooked up and is pivoting on the anchor. A guess a few have already probably made.
There are times when despite every effort things go south.
