KNG2-P150 Channel Selection
willgoldsmith
We have 4 new KNG2 - P150 radios for our wildland fire team. We have 23 channels programed into a Zone. The channel selector goes to 16. As I have done some You Tube research I should be able to type in the channels beyond 16 on the key pad but it seems that I am unable to do that. If I type in 17 I am getting a tone and no ability to go further.
Any Idea how to enable the keypad function to get a channel beyond 16????
waynedc
Vail, Arizona
What does your programming look like for the areas I have circled in RED on the attached image? In my example, the programming of the SIDE BOTTOM button is optional and could be set for any of the other buttons on the radio.
DanRollman
Atlanta, GA
In my radios typing directly on the keypad enters a zone number. Not sure if there is a way in the software to make that enter a channel number rather than a zone number.
DanRollman
Atlanta, GA
Side Bottom above the PTT is back Lite Settings
Side Bottom round button is Bluetooth
That depends entirely on your programming. I have mine programmed so that the Side Bottom above the PTT is Site Select and Side Bottom round button is Program Scan List. There's no factory default for these settings. Your programmer decided.
waynedc
Vail, Arizona
willgoldsmith,
I just tried it again on my KNG2 and my KEYPAD SELECT (for both conventional and trunking in the RES software) is set for CHANNEL. Pressing any number on the keypad allows me to change channels.
Just from past experience, it is not very common for wildland radios to be programmed with zones that have more than 16 channels. That is not to say that you can't do it and I can verify it can be done and it works on my KNG2.
Wayne
952Media
You can designate functions of the buttons in RES. I use the up and down arrows for channel selection beyond 17
willgoldsmith
Thanks everyone for your advise. It sounds like I need to sit down with the programmer and get into it a bit more.
