KSIC
radiomankc
Hello, im in the KC area and am not picking any traffic on the KSIC Mission or Olathe towers. I have the control freq programmed in, along with TGs relevant. Am I missing something? Are these sites still active in the KC area?
Thank you in advance!
nd5y
Wichita Falls, TX
Are you getting control channel data?
Program ALL the frequencies as conventional and listen for a while and see if you hear a control channel or anything else.
radiomankc
Thank you. I did you that but didn't listen for data/voice on any freq. I will give that a try. Thank you!
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Not exactly sure where this thread should go but it doesn't belong in the Database forum as it's not a database issue.
I took a guess that KC might be Kansas City and moved it to the Kansas forum.
nosig55
I think Olathe and Mission are on the MARRS and not KSIC
bctrainers
Olathe, KS
Anything in the Kansas City metro is vastly on the KC MARRS system.
KSICS is used in JoCo, WyCo, and so forth. However, not used for much of anything in the metro corridor counties due to KC MARRS. Regardless, the JoCo tower is indeed alive and well. JoCo ECC (30101) on MARRS dual-broadcasts dispatch from time to time on the Miami county fire KSICS talkgroup of 675 from the JoCo and MiCo ICS towers.
Douglas County has one or two talkgroups configured on the JoCo KSICS tower.
edit;
One thing to note is that the JoCo KSICS towers commonly serve Kansas Highway Patrol, KANG, KDOT, and AMR/EMS. On JoCo KSICS, from time to time, you will hear KHP Troop B, G and H key up on their primary dispatch channel. KHP Troop A is mostly on MARRS, but generally does have a bridge active between 1199 on ICS to/from 31501 on MARRS. KDOT's zones are hit and miss on JoCo KSICS for which are covered. I've heard KDOT Topeka district and KDOT Chanute districts come over JoCo KSICS in the past years.
KANG does come over KSICS from time to time, especially during severe weather season. They do a state wide broadcast of hazardous weather as it happens. Same with NWS in Topeka KS - i think they're on 1231 or 1232.
bchappuie
Olathe, Kansas
All working fine for me here in Olathe. KHP Troop A and G, KDOT. Might check your control channels they seem to rotate them around on regular basis.
