LA County Fire "Future Use" freqs testing
xilix
Pasadena, CA
From a brief listen this weekend, it appears that the "Harvard Sentences" on the new freqs have stopped and there's now traffic.
I am hearing dispatch traffic on the new D2, D3 and D4 channels. Blue-1 appears to be patched to D2 - I heard Avalon traffic on the channel today. I would have thought the Avalon traffic would be on D5. Similarly, Countywide dispatch Blue-8 is patched to D3 & D4.
Also, C44, C45, and C11 have dispatch traffic.
Just a guess on my part, but I am thinking the radio techs are still testing and they want to hear how real traffic sounds thru the system, so maybe that's why the seemingly random patches ?
Anyone know of a "go live" date for this system ? With so many radios involved, including those of outside agencies, I wouldn't think it would be done during wildfire season (admittedly, is all year now).
avascan522
Los Angeles County, CA
Since everything is patched, the new channel assignments don't directly line-up with the Blue channels. For example, Catalina traffic is mixed in with LA Basin battalions on Blue-1. In the future, "Catalina and Coastal" will have its own TRO channel. I can only speculate that in the future, D-2 and D-5 might be patched together from time-to-time since TRO's at C&C have been known to cover multiple channels during a shift. That happens currently with the Blue channels as well. Just tonight I heard Blue-5 and Blue-1 patched together, wondering why I was hearing SGV foothill traffic on Blue-1.
I do believe that the radio techs are just mixing and matching in order to semi test-run the new channels. I've heard a few hiccups with audible echoing and distortion. They will most likely want to iron-out those issues before the new config "goes live." Personally, I like the new configuration and think it will fit LACoFD much better. Even if some areas are spotty with repeater coverage, being analog conventional gives FF's the ability to use direct on the repeater output on an incident. Also easier for outside agencies to use other brands of radios and makes programming easier without multiple TRS's in the radios.
avascan522
Catalina Island resources have received permission to use Command-50 as their island-wide command channel. Station-55, Baywatch, and Avalon Fire have done various coverage tests and the new coverage is sufficient for their operational/interoperable needs. Primary Avalon dispatch will still remain low band, however. Isthmus dispatching will continue to take place via landline, or C-50 if away from station.
tsalmrsystemtech
Couldn't say it any better. Maybe with LACOFD staying on UHF Analog might save them in the long run. Sound like they must have good techs with smart minds looking at their long term future. Hope LA City stay on 800 mhz analog too.
LACC
Indeed. Catalina will use Command 50, 51, 52, & 53. Dispatch 2 and Dispatch 5 will be a constant patch for TRO communications with “LA”.
LACC
Techs have been done. The system is now in the hands of Field Comm who is putting it thru voice coverage testing on all bands.
tsalmrsystemtech
Heard this new UHF channel tonight for a resuce with a vessel taking on water at Catalina. Nice
483.1625RM151.4 PLLAC C-50Command - Catalina and Coastal
avascan522
You mean right now? Haha, yes, I'm listening to it too. Island county resources have been using C-50 as their interior primary channel for about 2 weeks now. LG Catalina is a backup since some SAR radios still don't have the new UHF codeplug programmed.
tsalmrsystemtech
Yes must of heard it at the same time. Tried to listen to their A/G but didn't hear anything. Most likely it was not a big deal. Probably got some pumps onboard and pumped the water out before it sunk.
avascan522
Not sure if there was a call earlier, but there is one happening now. (Sun, 20:20hrs)
BW Isthmus is just arriving on scene. Reported injuries onboard. Sounds like P155 will be LZ coordinator. Poor volly call FF. 😂
xilix
Pasadena, CA
UPDATE: I am told the targeted GO LIVE date for the "Future" freqs is Jan 8th.
Progline
Central Washington State
I gotta ask: What happens to the old UHF and VHF CMD channels? And the VHF fireground/Tac channels as well? Is there a plan to retain the legacy system for a while?
avascan522
I believe the VHF channels will remain for fireground and wildfire uses. The new CMD channels just replace U-15/16/17/18D. There aren't that many UHF command channels in the old config, so the new config changes that.
LACC
Legacy UHF Simplex:
-Some built into LA-RICS as infrastructure.
-Some repurposed and re-aliased
-Some newly licenses frequencies
VHF Repeated & Simplex:
-No change besides massive site build out
-Will be used for wildland only
Old UHF Repeated:
-Repurposed to data “NMDN” channels for the MDC system
