LA County Fire "Future Use" freqs testing
PacScan
Los Angeles
The DISPATCH talk group is now only brought down based off subscriber affiliations.
That makes sense based on my testing today, only heard traffic at points (site held to Downtown 700 or West 700). Personally (as someone who listens daily) I would love a full patch given the reception and clarity on LARICS is so much better for my location, however I can understand it would not be typically needed in practice. Got curious and had the time to compare. 😂
avascan522
Los Angeles County, CA
As mentioned, all Dispatch channels along with the first up Command channels for each are up. All other commands coming soon. Maybe even LAC A/G. Working on filters to remove the key tones. Thanks to the Los Angeles County Firefighters Association for funding this huge project!
You should hear the same traffic on D-2 & D-5 24/7. Same traffic, different repeater coverage.
DPK, TPK, BJM, & two main land sites (RHT & CCB).
Yes. For All Hazards incidents, you will see the COMMAND## phantom unit ID.
Correct. The simulcasts were built for their geographic usage. LAC U-1 & U-2 are countywide.
See above quote re: feeds. 🤙🏼
I remember some mention of Signal Hill in the RICS JPA board agendas. Was that site scrapped for Catalina & Coastal TRO-5 channels? Would seem like a more ideal site than the Compton courthouse.
n2snm
Sentinal Software help
I am fairly new to my SDS100 and trying to program LA County Fire Dispatch 4 via the Sentinal software. Can someone point me to the correct directory within the software where I can find the proper frequencies to add to a favorite group?
I tried loading the LA-RIC\County Fire directory, but I am not hearing anything.
Engine104
Member since 2005
Winnetka, CA
N2SNM: I think you'd do better loading the new LACoFD conventional UHF frequencies. They are listed in the RR database. Most of the communications (Dispatch, Tacs, etc) are run on those freqs.
