Lake Ontario Coast Gaurd
ab2ms
Fulton, NY
Listening in to a possible lost raft search on Lake Ontario, Oswego county area. They are mentioning the coast guard coming in to help and I'm wondering if there are frequencies for this area to scan, or should I put in the whole big list. I'm just south of Oswego.
alphaacres
Oswego, New York
156.80000 BM Marine16Hail Ch. 16 International Distress, Safety and Calling FM
157.05000 BM Marine21A CG Ch. 21A U.S. Coast Guard FM
157.10000 BM Marine22A CG Ch. 22A Coast Guard Liaison/Maritime Safety Information Broadcasts FM
157.15000 BM Marine23A CG Ch. 23A U.S. Coast Guard FM
157.12500 BM Marine 82A Ch. 82A U.S. Government only FM
157.17500 BM Marine83A CG Ch. 83A U.S. Coast Guard only FM
If air search is used channel 82 ,83
Maritime Scanner Frequencies and Radio Frequency Reference
D
DaveNF2G
Guest
Just an FYI, if there is a Coast Guard air search, the aircraft will be coming from Detroit. It has happened before and it's pretty cool to monitor.
ab2ms
Fulton, NY
Thanks, didn't hear anything on their frequencies, but did learn they have a CNYICC radio and we're communicating with the local departments on "fireground 7'
Sent from my SAMSUNG-SM-G900A using Tapatalk
ecps92
Taxachusetts
Most of the CG Ops would have been on their own P25 VHF/UHF LMR Network
United States Coast Guard - The RadioReference Wiki
They generally only use the VHF Marine channels when interfacing with external agencies
D
DaveNF2G
Guest
That is a localized condition. If the P25 infrastructure is available, then they will use it. If it hasn't been built out yet, then they will be where they have always been, as alphaacres listed.
In the Albany, New York, area, what CG ops do take place are on a system of VHF analog repeaters, along with the usual marine band channels.
ab2ms
Fulton, NY
Now that I have a spare scanner I'll set it up to scan / log the coast guard frequencies to see what if any channels I can hear.
geartow
I have seen blackhawks flying grid pattern over onterio , would guess they are out of ft.drum ,during searches.so maybe some army freqs.
ecps92
Taxachusetts
Curious, what Analog Repeater frequencies ?? :confused:
D
DaveNF2G
Guest
150.700 with a different PL for each repeater.
Technically CG Aux, but I have heard actual CG assets doing radio tests from time to time.
ecps92
Taxachusetts
OK, had me baffled as the USCG LMR is P25
Yes, the USCG Aux - however Yes various CG Assetts do have access to it
D
DaveNF2G
Guest
Yeah, sorry, I get annoyed when other people screw up the nomenclature. This time I did it. Oops.
ecps92
Taxachusetts
Hey we all make an error once n awhile.
Your good till next month :)
PS - the 3 nearest Albany P25 Sites are:
Name Catskill
Latitude__DD_MM_SS_SSN 42-12-34.00N
Longitude__DDD_MM_SS_SSW 073-53-55.00W
Name Troy
Latitude__DD_MM_SS_SSN 42-47-09.00N
Longitude__DDD_MM_SS_SSW 073-37-41.00W
Name Whitehall
Latitude__DD_MM_SS_SSN 43-30-48.00N
Longitude__DDD_MM_SS_SSW 073-18-18.00W
