Laptop for programming
Matt9638
Can anyone recommend a good laptop for cps programming other tough books?
Your question is a little off kilter... are you wanting to program a Toughbook computer or want a computer to use for programming using CPS? Programming a Toughbook doesn't make sense but, I believe you're looking for a computer to use for programming other than a Toughbook?
Matt9638
Sorry. Used an iphone for this message. I want to use a laptop OTHER *THAN toughbooks. Lenovo, dell etc. witch do I want to use? Just need it for the programming, using CPS , xts/xtl software, and apx software. I have all motorola usb cables already
MTS2000des
5B2_BEE00 Czar
If you are only working with MOTOROLA SUPPORTED products that you named, than any modern laptop with at least 4GB or more of RAM will work fine. Obviously since your cables are USB a working USB 2,0 or faster port or two or three.
Windows 7 32 bit is my choice for O/S. But CURRENT MOTOROLA PRODUCTS you named support higher versions of Windows. Always check the README files in your CPS folders for specific requirements.
Now, if you want to program older NO LONGER SUPPORTED CPS based products such as MTS2000, MCS2000, XTS3000, Astro Saber, Astro Spectra, etc. than the requirements are different.
Brands of laptop really don't matter. They are all made in China by the same sweatshop OEM'ers like Compal, FoxConn, etc. Business class machines (e.g. Dell Latitude, Thinkpad, etc) are generally built a little bit better than the garden variety consumer plastic stuff at Wal-Mart at $199.
