Hit_Factor
I have put together two systems, Michigan and Indiana, for a start.
Each System is listed in a CSV file that may be imported into Unication PPS, I'm using version 3.16.9 at this time.
When you import the file, there is a display anomaly on my computer, I click select all and then OK. Enter the WACN ID(HEX) and SYSTEM ID(HEX) and that should do it.
When I click on the site list field PPS throws an error, but everything seems to be working OK.
To create the list I removed all of the non-control & non-alternate freqs from the RR DB download. Then removed all of the duplicates. On especially large systems, it might be necessary to remove the alternate freqs.
If you have create a similar file for a TRS You can send me the CSV and I'll post it. Start a conversation (private message) with me and I'll give you my email address.
