Let's build the PlanePlotter network in the U.S.
samson512
Austin,TX
Have a mircroadsb on the way, hoping to get some coverage set up for the central Texas area. Is it possible to share data with more than one of the networks?
CalebATC
Blairsville, Georgia
Well yes! You just have to run more than one program specified for that website, but it will increase your bandwidth usage.
If you have anything better than 500Mbs upload, you shouldn't notice a difference at all. Don't worry about bandwidth though, it shouldn't be a factor unless you are using dial-up :)
samson512
Austin,TX
500 megabits /s ? I'm more around .5 megabits /s upload.
CalebATC
Sorry there! I just realized that... thanks for your correction!
Yes, anything a half or megabit or better upload will work perfect if your running a few different uploaders, and you probably won't even notice a change.
Yokoshibu
So do we need to restart this as "lets build the planeplotter MLAT network across the US"?
bbrasmussen
Woods Cross, UT
Rebuilding this thread or starting a new one would be good. We need more MLAT coverage especially here in the Western US.
Yokoshibu
I agree completely. It's nice to see Colorado is built out... It wouldn't take much fill in the rest of Utah / Nevada and Arizona... considering there are stations in las vegas, Pheonix, LA... we just need to find people in-between... therein lies the problem. We need towns like Cedar City, UT, Reno NV, Bakersfield Ca and the like.
edited.. also need Tonopah Nv, Palm Springs Ca, and Yuma Az, ... those 6 locations in addition to what already exists would probably cover all of Ut, most of Ca and Az and Nv... come to think of it 2 more stations at Tucson and Albuquerque would most likely cover all of AZ above FL230. So add 8 stations and we would multiply our MLAT ability by.... 4 states... pretty good.
jmhayes
San Francisco
Just as a reminder to those of you contemplating feeding PlanePlotter: you should also consider feeding to this site: Military Air planes with Mode-S ADS-B ... this is a great historical database resource, and it also helps to find new sharing opportunities because the location is well identified.
Yokoshibu
that site has live tracking? or do they just have logs? cause i am wondering how i feed them vice upload logs.
vagrant
ker-muhj-uhn
California
My ID in planeplotter is iX, feeding from Northern Illinois
Are you planning on sharing 24/7 or whenever your computer is on? I do not see your ID at the moment, so I am presuming the latter. The time now is 0511 UTC. Still, even if not running 24/7 your feed helps when you are sharing.
FLANO
AZ DB Administrator
SE of Tucson, AZ
I am "eD" in the Tucson area. I run an SBS-3 24/7. There are also four dongles operating in the Tucson area, not always 24/7, but pretty close.
I agree that Yuma would be real nice to have. But it would really only fill the hole from CA. There is not much activity over the Barry M Goldwater Range.
I can tell you that when my SBS-3 is off line, I know it. I watch PP from my work location and can tell when there is an issue. I have excellent "visibility" in this area, seeing down into Mexico and up to Phoenix and Flagstaff, as well as south western NM.
Deming, NM would be another good place for a radio.
FIREBOX2914
MARYLAND
I run plane plotter ID= "bv" in Maryland. It runs usually 24/7 still not 365 yet. Im using the RTL2382U dongle with RTL1090.
D
DaveNF2G
Guest
You should be using DUMP1090 to feed the Planeplotter network. The requirement was imposed a couple of months ago.
PRRESCUE
Just installed my system total investment was around $40.00 by re-using a old scanner antenna I had. I am using planeplotter and VRS check it out prradar.ddns.net:100/virtualradar coverage for Puerto Rico and adjacent waters.
P.d In the next couple of days I will be installing a new antenna in a mast even higher so coverage will improve. along with ACARS decoding all using little SDR's dongles.
planeplotter ID mr
vagrant
ker-muhj-uhn
California
Your potential for coverage will help that area quite a bit. Some additional height may help clear your antenna of nearby obstructions. What kind of range are you getting? If you're getting around 300km now, I would not worry about improvements to your system. If you're getting aircraft just West of Anguilla across to the Eastern part of the Dominican Republic, your system is working well, as that's about the maximum range when planes are around 10km in the air. I am not sure how much traffic/flight path is over your area at that altitude though. My guess is you may have more lower flying aircraft going from island to island, so the range would be considerably less. Rather than my guessing, please share your experience after you have had a chance to review your results.
PRRESCUE
Hi,
I am getting around 200 planes a day mostly to the NW (Direction of the Airport) 100 - 150nm out. I have some obstructions to the East towards the island and west into the Arrival Path, when I increase the antenna this weekend I should avoid some obstacles and let you now. So far after 10PM or so i do get a lot of flights from south america to Europe during the day lot of local traffic to and from SJU. Still not too much inter island traffic.
