let's see your vintage radios!
zob-slantzero
North Central Ohio
Found this radio on Craig's List and a call sign was etched on the back. After Googling the call sign and following a very interesting trail it turns out that one of the Cryptologic Technician's that was captured by the North Koreans while serving on the USS Pueblo once owned the radio. After learning that I decided to ship it to Ron Baker in North Carolina to be refurbished, I think that he did a wonderful job on it. I feel that due to the lineage of the radio it was worth doing it right and hope to continue to use it as long as I can.
Buckeye, AZ
Just got my frg -7 that I got off of eBay. It's the Sears branded one, but one of the previous owners ripped off the emblem. It's got some scratches and marks, but overall it's a nice radio. The last owner changed the s-meter & main tuning dial lights with LED lights which gives of a nice white light. Never used one of these before so I'm still trying to figure stuff out but it's a fun radio!
Sent from my SAMSUNG-SM-N900A using Tapatalk
Boombox
Beautiful radios you guys have. Digging the photo of the Drake R-4 and the FT-101's.
RE: the FRG-7:
Very cool radio. Haven't seen a close up photo of the Sears model before. I notice that the bandswitch and mode knobs are different than those on a stock Yaesu FRG-7.
I've had an FRG-7, so here are some tips, maybe you already figured out most of it, though....
FRG-7's are excellent radios for MW DX, and SW listening / DXing. Bandwidth is a hair wide for some SW DX, it depends on how crowded the bands are, and over the past couple years (at least here in the PNW where I live) the bands aren't that crowded... so bandwidth may not be an issue. Excellent sound -- either through the speaker or headphones -- makes DXing a pleasurable experience.
Just remember that when the red LED is off, the Mhz dial is correctly tuned. And you will also notice that when the Mhz dial is a little to one side or the other it weakens reception a bit, so zero it in for best performance.
As you probably have already noticed, the DX / Local on the Attenuator is backwards -- the 'DX' setting actually kicks in the first stage of the attenuator. They labelled it that way on all the FRG-7's at the factory. One of it's labelling 'quirks'. I leave mine in the center position. Never had to attenuate signals, except very rarely on sideband.
The FRG-7 is good for monitoring the ham bands, but the wider selectivity can make strong adjacent stations cover weaker ones. It still can be done, though. I used to use it exclusively for monitoring the ham bands, just lived with some of the QRM. When conditions are good and there's low noise, listening to the ham bands with a set of headphones is a pleasurable experience.
The ANL is fair -- as you probably have noticed, it doesn't really reduce noise much. I upped the capacitance on mine, which improves the noise limiting a little bit (also cuts some of the highs), It makes it more useful, but it's definitely no where near a noise blanker.
There are numerous modifications that can be done. I only have done the ANL mod (adding a capacitor) and I also did a 'mod' where you disconnect a resistor that's across one of the segments of the bandswitch -- I think it's across preselector bands A & B -- I don't quite remember, and don't have the schematic handy. Some guys wire back-to-back diodes inside the radio, near the antenna input, to protect the RF amp FET from static damage. I clipped a couple into the antenna terminals on the back of the radio -- does the same thing.
Buckeye, AZ
RE: the FRG-7:
Thanks for the tips, I really appreciate it. I watched a lot of YouTube videos before I received it and also read as much as I could about it doing Google searches. Pretty straight forward and easy to operate, thought it would be a little more involved than it actually is. The audio on this thing is very pleasant, I'm really happy I decided to buy it! Fun stuff!
allegro8m
name of the radios
OK, Ridgy, here's a selection.....
The Blaupunkt is a surprisingly good HF performer even on a short bit of wire - can't beat tubes!
My favourite rig - was a POS when I bought it, but responded well to a cleanup and realignment. Ultra stable and sensitive. Came with a memory unit but some tosser left the batteries in it :roll: - took along time to get that going - even resorted to scrubbing the PC board in a bucket of hot soapy water - still a bit flakey.
The Heathkit is nothing special, terrible audio and wanders all over the place. Nostalgia value only!
hello, can you tell me the make an model of the last two radios in the picture?
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
The NRD is almost certainly the venerable NRD-515 - a real workhorse in its day among many DXers, both utility and SWBC
Mike
allegro8m
hi there, thanks, but can you tell me the brand and model of the receiver above the heathkit gc-1? thank you , regard.
ranieri
majoco
Stirrer
New Zealand
Yes, it's certainly a JRC (Japan Radio Corp) NRD 515. They made many marine receivers and a series for amateur use, the NDR 525, 535 and 545 but after that faded away. Since the advent of GMDSS there are no more radio operators on board ships so no requirement for separate receiver/transmitters. There is/was a companion transmitter for the NRD 515, ISTR an NSD515, but now I think they concentrate on HF telephone using transceivers. I bought the NRD 515 in very used condition complete with speaker and memory unit around 2006 - rather off frequency and off tune - from the stickers on it, it came from the JAL office in Auckland and I think it was sold off when we went from AM to SSB as the memory unit had all the old AM frequencies installed.
The Heathkit GC1-A is usually called the "Mohican", a kitset - all flash but not really any better than say a Zenith 3000-1.
Don't forget I'm a few hours behind you guys, but a day in front...... :)
allegro8m
hi, i get it, i also have a JRC 535 HF GOING VERY WELL, one yaesu frg7 wich has become less sensitive, a zenith royal 3000-1, and royal r-7000-2 wich work very well and without creating problems, an when i go on vacation a grundig satellit 3400 prof
essional and pan crusader-s 12 band. but my favorite is DRAKE R7A.
hi there
ranieri
