Lincoln County
SYZ1165
Hello, I have a friend who is and has been listening to the Lincoln County portion of the MISWIN. he is using a Whistler handheld scanner with a short antenna. Is this system simulcast? If so, we know what the issue may be if not, what scanner would you recommend him trying to purchase for this system and monitoring LINCOLN county Mississippi? I know the SDS 100 would do it but that’s kind of expensive. Is there another SCANNER that would do the same job in the unit in sCANNER portfolio thanks.
slhbeard
Vicksburg, Ms
I don't think they are simulcast. I have a SDS200 and BCD536HP which receive them well. There is probably a cheaper scanner than that will do the job though.
RMason
Mississippi / Colorado
To my knowledge, Lincoln County is not simulcast. What issues are you experiencing? What Whistler scanner are you using? (is it capable of decoding phase 2?) What antenna?
RMason
1 (1)032 (20)Brookhaven EastLincoln771.83125774.05625774.30625c774.55625c774.80625c
1 (1)033 (21)Brookhaven WestLincoln769.18125769.43125c769.68125c769.93125c772.43125772.75625
both sites show 2 towers, so yes simulcast.
also do you have the closest one in the radio or maybe both ?
Nothing in the RR db listing or license information indicates simulcast. The towers shown on the map are the two Lincoln County sites - #1: Brookhaven East and #2: Brookhaven West. Each site has a single tower. The sites do not share the same frequencies. This is not simulcast. (This is a common configuration in MS)
LocFrequencyEmissionClassUnitsERPLatLonCityCountyState
1771.556250008K10F1EFB21158.00031.57511-90.332BROOKHAVENLINCOLNMS
1771.556250009K80D7WFB21158.00031.57511-90.332BROOKHAVENLINCOLNMS
1771.831250009K80D7WFB21158.00031.57511-90.332BROOKHAVENLINCOLNMS
1771.831250008K10F1EFB21158.00031.57511-90.332BROOKHAVENLINCOLNMS
2772.431250008K10F1EFB21191.00031.53344-90.52572BROOKHAVENLINCOLNMS
2772.431250009K80D7WFB21191.00031.53344-90.52572BROOKHAVENLINCOLNMS
2772.756250009K80D7WFB21191.00031.53344-90.52572BROOKHAVENLINCOLNMS
2772.756250008K10F1EFB21191.00031.53344-90.52572BROOKHAVENLINCOLNMS
Whiskey3JMC
Don't feed the squirrels
Simulcastylvania, TE
RMason
wtp
Port Charlotte FL
yes, i am quite well aware.
but first you need the frequencies.
then you program the talkgroups you want.
and we were talking about simulcast, i could not find the frequencies for the towers as that would then really tell me if the problem was simulcast.
