LMRN Technical Data Discussion
dvdbir
Here in Timmins, the MOH is using 771.84375 mhz with a PL tone of 110.9 hz
ATCTech
142.665 now active with the 1038 Hz test tone in P25 mode. Britannia tower perhaps? Too strong here to be very far away from my QTH.
Jradioptbo
Peterborough, Ontario
Visiting family for Thanksgiving. Passed through Ingersoll. Picking up BEAT repeater 772.13125
I also hear what appears to be a beep, like a beacon every so often. The range of the repeater seems comparable to the old UHF repeaters.
ATCTech
142.635? Normal FleetNet (matter of fact analog EMS) traffic here, otherwise no other signal on that frequency from my QTH north of Hamilton.
icarus1963
Brantford, Ontario
Sorry for jumping the gun. Even with my gain set low, I'm getting blasted by interference today. The local LMRN signal if very strong from my location, and will often overload my SDR. Using my scanner instead of the SDR I too am just getting a lot of analogue EMS traffic.
ATCTech
No worries at all, I thought maybe you'd unintentionally transposed 142.635 from the "stray" 143.625 P25 test tone signal I posted a few weeks back. It's still active.
mikewazowski
Forums Manager
Oot and Aboot
If you monitor using DSDPlus, you'll see that the beacons are P25 packets between the DVRS in the car and the portable.
IdleMonitor
Is this a BEAT Repeater? or a mobile repeater? Further up this thread, 772.13125 was identified as a mobile repeater. Also, as Mike pointed out, the beacons are per mobile repeaters so...
Jradioptbo
772.13125 was also a BEAT repeater in Alliston. I am not sure if the frequency is an allocation to BEAT or Mobile. But I indeed did get that on my scanner in Ingersoll. Also is the beacon P25 packet specific to only Mobile Repeater to portables and/or BEAT Repeaters to portables? These packets were intermittent during the transmission. Ingersoll did have an old UHF repeater before the switch over to 700MHz
mciupa
Canadian DB Admin
Moderator
I'm here a lot
My uneducated guess is that the Mobile Repeater PL tone would be static and not vary. Alliston and Ingersoll have different PL's for their locations.
ATCTech
I'm now seeing this on the 142.050 P25 LMRN frequency rather than the typical TG=1 RID=1 associated with the 1038 Hz tone. It's admittedly a very weak RF level for me on that one but is it valid or just garbage I'm decoding?
gary123
Have seen 142.110 active out of Tavisock. 143.085 is silent. Will try for a capture to verify very soon.
gary123
I drove by Tavistock and it's not coming from there. There is no CC coming from the site. I did a complete VHF sweep138-174. I will see if I can grab some site info from the 142.110 signal. I did pickup Woodstock on 142.530.
gary123
773.03125 136.5 EMS heard. Sounds like Oxford but super staticky
