Load NX5000 portable plug into a mobile
otobmark
NC
How do you get a portable plug into a mobile without having to re key everything in? Cut and paste is too limited to help much (only lists—TG and RID)
kd4efm
EL98 Florida
Mark, and others
Product information
Change from mobile to portable or portable to mobile
like 57 to 5200 or 58 to 5300 (and model style( k, k2, k3 so forth)
Make sure it has like features
Make key assignment changes.
Load and go.
tlemke940
Lyons, OR
First is the two radios the same band split? do they have the same feature set? if so most of the time you could just change the model and then set the model specific things like the key layout. if they are not the same band split it is copy and paste. if the feature set is different then it is still possible as long as you take out anything that incompatible. the software should come up with a window that says what is incompatible when you go to write the file
otobmark
NC
Split is the same. Need to update firmware on mobile and install some licenses.
Thanks guys.
