Los Angeles Regional Interoperable Communications System (LA-RICS) - Master Thread
LACC
Someone can correct me if I am missing something but I don’t think it was ever down. The talkgroup will only work when someone affiliated is on it. I hear it from time to time with no set pattern, most likely when someone on the admin side at LACOFD has it on in the background.
100%.
LACO FIRE BLUE 8 COUNTYWIDE ( DIGITIAL)
is back up and running
What cell are you affiliated to?
chainsawman
Simulcast technically means "at the same time." In the case of the RICS system, and many trunked systems, if you have a simulcast "site", then all the towers in a specific area will transmit all the same traffic as if they were one "site". Some trunked systems have "standalone" sites, where there is only one "tower" associated with the site. With East Simulcast 700, for example, there are many towers associated with that "site" that all broadcast the same traffic.
You probably wouldn't hear dispatch traffic from Malibu since those units would be using West Simulcast, either 400 or 700. However, if a subscriber radio (a radio that is affiliated with the system), turns their radio to that channel/talkgroup, the system will recognize that it wants to listen to that channel/talkgroup and activate it on that entire "site", which would be East Simulcast 700. When that radio changes channels or gets turned off, then the "site" will no longer put-out traffic from Dispatch-10.
Hope that all makes sense.
Thanks! So, I put a radio up at a friend's house in Malibu and so far we've only heard transmissions for Aero Bureau dispatch and some Special Units.
Any idea why that may be the case? Since it's all part of the same system, I thought as long as I have the talkgroup programmed in (looks like decimal value 310 according to RR), I should be hearing Dispatch 10 if I'm also getting Aero Bureau.
StephanBH
Los Angeles & Berkeley, CA
Dispatch channels (including dispatch 10) are still on the old non-trunked frequencies. All TACs and special units dispatch are on LARICS.
chainsawman
Thanks... unfortunately, it looks like Malibu L-TAC is encrypted on LARICS now? :(
We tuned the radio to listen to the dispatch on the old frequency and it's surprising how little action comes through. Mostly just beeps.
resnickm
LA <> NYC
Unfortunately all L-TACs are encrypted on RICS (along with their “Metro” channels that they are using pretty often based on my listening). It’s a real tease when there is something ongoing, but hey, at least dispatch is still clear…for now.
