Lost all my systems except NEXEDGE on scanner.
ProScan
Software Provider
Ontario, Calif.
Lost all but one system on scanner. Using Proscan.
It could be a few reasons. You could have had 1 system in the database and you checked "Delete All Systems In The Scanner". It's always a good ideal to download from the scanner first so you can see what's in the scanner and the ProScan and Scanner databases are in sync.
Whiskey3JMC
RTFF
Southeast PA 🇺🇸
You'll need to re-download what you're missing from the Radioreference web service feature in Proscan
Database --> Import • • RadioReference Web (Subscription Required) - Imports data from the RadioReference Web Service.
jrf19
Arkansas
ok i wil try that. What is a safe way to shut Proscan off? How can I save settings if I get it fixed on a computer file?
ProScan
Software Provider
Ontario, Calif.
Why was your post deleted? No. I got that one back.
I was in the process of making a better screenshot. If you got that back then why are you asking " RR Database will not let me find Baxter County Mototrbo sheriff dept freqs"
jrf19
Arkansas
I got my NEXEDGE files back, it is my Baxter County AR sheriff MOTOTRBO files I cannot get thru RR import. I cannot find MOTOTRBO option there
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
I suspect you are simply looking in the wrong place. There's a sheriff patch on tg15 on the Mountain Home trunk, but the sheriff frequencies are mostly DMR- for which you can update your scanner - and shown here
I strongly suggest you spend some time on the wiki article I gave you earlier...Mike
jrf19
Arkansas
Thank you. I will see that wiki article. I appreciate your help and patience.
