Currently working with NMO mount, and various telescoping things and a long OEM Moto rubber duckie, but looking for what would work best in an apartment. I have a BNC low-band Unication wire antenna I an deploy, the previously mentioned low band NMO whips, but simple logic such as put it in the window for best RX doesn't pan out. (windows are not RX inhibiting) Against a back wall, floating in the middle of the room, on the floor, it is just hit and miss and the hand -on-antenna effect makes testing locations problematic.
For the wire option, should I string around a window, should it stay straight, vertical, horizontal, around the window, diagonal across the wall, strung from a lamp to my TV...any tips as to what should work best would be appreciated.
Paul
Paul
