LTR mapping - Same GGG=same service???
rc1990
Sudbury, Ontario, Canada
Hey all,
I'm currently trying to map a LTR system use by the local hospital. It is a LTR standard system and has 3 system frequencies. The radio system is use in 5 different buildings around the city (all affiliated with the hospital) with each their own HH (HH= 01, 03, 05, 07 & 09)
I need some help with IDing the TGID (A-HH-GGG format). The hospital itself uses 1-01-061 for security. I logged 1-05-061 (from that building) and 1-09-061 (from another building) . Would it be safe to generalize the GGG with the same purpose at different buildings : like all TGs with a GGG of 061 is security? Quite a few GGG come up more then once in different buildings.
I have attached a Word file of the TGs ID I found so far in the LTR system. As you will see, there's 2 TGs that have an area code of 0 while all the others start with a 1 Also, there's one TG that has a HH of 25.
Sorry if this question is repetitive. I quickly looked at the 17 pages of threads in this section/did a few search of the forum and read a few Wiki articles on the subject with no success.
Any help would be appreciated!
Thanks.
  • Health Science North LTR mapping.doc
Voyager
That would be an elegant way to set things up. Easy to remember who is where.
BC_Scan
Vancouver BC
Stay on it this is good work. I have mapped all the local ones out here using the same process. Some observations. in LTR there are only 251 I think TG's, So for ex :1-9-253 Is the Repeater ID
The misc ones you have hear do not exist as you only have LCN 1, 5 ,9, you have a fourth freq but no LCN
it could be 7 as it stands to reason.
Once you are all confident in the the LCN search away, write them all down listen for what the people are doing , with your list this big, you can have security which has three channels, but access to all the other channels as needed,
I have also seen instance's where ex: 1-01-101 is base radio & id's 102-150 are the actual radio's , same channel but the id shows up, ( I believe that is called loading) it gives the appearance that there are more users on a system. it justifies the need for more frequencies.
Steveradio
LehighValley/Poconos Pa
my local shop does the same for transcrete company how ever they jump from system to system but use the same ID say 0-03-098 and 0-11-098 etc..
They also host to a white water rafting group same thing, They call on different system tower groups
