LTR Systems with missing LCN's
John_M
Rochester, N.Y.
I want to monitor an LTR system, can I do this with missing LCN's.
The LTR sytems that I would like to monitor are Monroe County N.Y.
INDY72
Indianapolis, IN
Depending on the svcanner you use.. YES....
With a PRO-92, PRO-2067, PRO-2051 *As far as I can tell* You only need to set for LTR and put the freqs in....
With others especially the Unidens, and the PRO-97, you MUST put in LCN order.
John_M
Rochester, N.Y.
Milf:
Scanner will be BCD396T. There are three LTR systems in my county (Monroe / N.Y.) Two of the systems have LCN's that are N/A. Take a look in RR and see what you think of these three systems, one of them has all LCN's listed the other two have LCN's that are misssing. I really want to monitor the third LTR system.
D
DaveNF2G
Guest
JMedley_1 said:
Milf:
Did you check the NF2G Scannist Pages to see if there is more complete info there?
INDY72
Indianapolis, IN
Correct on the info.. skip empty ones till you know what freqs fit there if any.... Some LTR systems have like only 3 freqs.. but are set up like... LCN's 3, 20, and 40.....
John_M
Rochester, N.Y.
There are a number of businesses listed as being LTR trunked. When I click on the "trunked" it says missing url.
pro92b
Mutated Member
The RR listing for Genesee 2 definitely has problems. There are listed ID's homed to repeater numbers 8, 14, and 17 but no frequencies are listed for those LCN's. Dave may have better information and you will have to monitor the system to confirm which data is right.
D
DaveNF2G
Guest
Almost every UHF system I have monitored Homes on repeater 4.
in connecticut, the town of cromwell has a home ch of 1.
the town of newington has a home ch of 3.
it depends on who sets up the system and what home ch they pick.
bill simpson
n1jbs
