M7100 Programming Error
BlueDevil
WA
I am using the ProGrammer Software version R18B02 to try and program 2 MA/Com M7100 IP radios. I have had grat success programming other M7100 radios however I am running into and Error with these 2 specific radios. Not sure what I am doing wrong.
Upon reading the radio this is the error message I receive: "Error - radio was programmed with a later version of radio Programmer software. Please contact Software Services."
Does this mean I am SOL?
DisasterGuy
Maryland Shore
Do you have a legit license for ProGrammer? If so, contact TAC or log into your Premier account and download RPM9.
If not, I'm not going to provide guidance other than to say you can find instructions here and on the net to roll the radio back.
ElroyJetson
The radios were last programmed with a higher version than R18B02.
So you can't READ them.
But you can just program right over them without reading them first, unless they have been set up to be RPM dependent. (VER will read 51 or more on the radio display when the REVISION menu is used and the VER display is called up.)
Unlike Motorola, where a radio is locked into being read and written by the highest software version yet used to program it,
you can always program a Harris radio with an older version as long as the firmware is still compatible.
BlueDevil
WA
It doesn't appear that I can write over the current programming. I am being directed to the radio maintenance program by the programming software...
Muxlow
Super Secret
Middlesex County
Id guess it was programmed with RPM and thats why you cant read/write with Programmer.
BlueDevil
WA
Is there an easy way to tell? I can access the revision menu from the remote head of the radio.
For whatever reason it is just these two that I am having problems with. They are labeled as M7100 radios however they may have been purchased at a different time than the others. They came off a couple Motorcycle Police Units.
BlueDevil
WA
I am able to read the radio files with the RadioMaint program that comes with the ProGrammer Software.
ElroyJetson
RadioMaint doesn't read the radio's files. It only reads certain data relevant to the radio's alignment and features.
You can read the ESN and feature string, and tracking data. That is not the radio's file that tells it what to tune to, listen to, and transmit to.
DO NOT mess with the RadioMaint section of the software unless you have been given instruction
in what you are doing. It is VERY easy to wipe your radio out and make it a doorstop.
