kd7rto
I've been getting familiar with the Trunkview program, now it's doing a flawless job tracking UP&L with my IC-R8500. Many other radios are also supported, and it can be configured to follow MPT-1327 conversations in either a one radio or a two radio (control/voice) setup. One nice thing to note is that if you find a voice channel, and do not know which system it is part of, Trunkview will display from the data bursts on it it's LCN, and the LCN of it's control channel. At the clear-down of a voice channel, a "return to control channel xxx" is decoded, and the receiver tunes back to it.
The first order of business was associating frequencies with LCN's. Unlike UTA, which uses the same formula across the band, UP&L requires a custom channels table. You'll probably still need to calculate the formula, as my setup has had some difficulty finding it's way back to the control channel if base and step are left blank.
I've associated enough LCN's with frequencies that any new once I find should be easily determined. For some reason, their table repeats itself.
152.03 through 152.24, in 15 kHz steps, are LCN's 1 - 15. They can also be assigned as 179 - 192.
152.51 through 152.84, in 15 kHz steps, are LCN's 17 - 39. They can also be assigned as 194 - 216.
I still have some things to figure out about 161.8 through 162.0. Here's what I do know:
161.8 = LCN 160
161.875 = LCN 166
161.925 = LCN 170
161.94 = LCN 171 Note that this last one deviates from the 25 kHz steps used when this range was in service for ship-shore telephone patches.
Control channels don't seem to rotate with voice channels on any regular basis.
To conclude, here are the two strongest control channels into my QTH in Bountiful. Most traffic has been units calling into the Salt Lake Service Center, ID 6046. Other service centers appear in the 60xx range...more info to be provided as I figure it out.
System 4899
188 152.18 control
200 152.6 (I observed control switch to this channel in one instance)
213 152.795
412 153.56
System 48B1
13 152.21
26 152.645
39 152.84
171 161.94 control
161.8 = LCN 160
161.875 = LCN 166
161.925 = LCN 170
System 4899
188 152.18 control
213 152.795
412 153.56
System 48B1
13 152.21
26 152.645
39 152.84
171 161.94 control
