Maryland FIRST 700mhz TRS
maus92
The OP
Interesting. I read the Unication white paper on P25 alerting and the cost of maintaining separate legacy radio hardware just to page vs. paging on P25, along with the other arguments to replace minitors with unications. I was sold. I was thinking of pitching the idea up the food chain to the powers that be in my jurisdiction as a beta program if our station buys the radios. I guess I assumed it would be simple - just hook up a few wires, pick an unused TG, and profit! Maybe its not so simple after all.
AFAIK it is still a recommended practice to have a seperate radio system for personnel alerting, although I'm not sure of the exact wording of NFPA 1221 wrt paging. A competitor to Unication has a different view:
riveter
MD
P25 alerting is a different thing from what you're thinking of. P25 alerting is done in system outbound data signalling and not by audible tones on a voice talkgroup. With the licenses (cha-CHING) and setup in place, I could group-alert 100 people with a job over a P25 system and someone with a scanner listening for voice traffic wouldn't have a clue. It's a lovely concept, but the implementation is clunky in the system architecture I'm familiar with, and it's expensive as hell both for infrastructure and subscriber costs.
Those audible tones linked seem to be just attention-getting alert tones, not functional pages. Most sound very similar (or identical to) alert tones from the old Zetron paging consoles we had at a prior employer of mine. That honking-sneeze one is the odd one out that I haven't heard before.
boatbod
Talbot Co, MD
Talbot is actively using 700Mhz paging via FiRST in areas where legacy VHF coverage is poor. I've been using a G5 in that role for well over a year now and been very happy with the results. It's way better than VHF but cost would definitely be a factor if you have to equip an entire department with $600+ G4/G5 pagers vs $325 Minitor/G1 analog pagers.
maus92
The OP
firebal
Baltimore, MD
The x's are variables and simply denote a range. As for how to enter in SDR Trunk, I can't help you with that.
I thought that it was that but just wanted to check to make sure. And pretty sure I figured out how to enter them. If it says 21199xx that means its 2119900-2119999 correct?
firebal
Baltimore, MD
Is 7648 MIEMSS Helimed the talkgroup used for MSP to advice Shock Trauma what they are coming in with? Basically a dedicated MIEMSS Med channel for the Troopers? I've been monitoring it for the past few days an haven't heard anything.
maus92
The OP
The 700MHz Helimed tg is not commonly used. The Syscom tg has some piss poor audio, so I would expect the same for Helimed; they *might* just be using the lowband Helimed channel for consults.
ThePhotoGuy
Maryland
Very rarely do I ever hear the Helimed talkgroup on Anne Arundel or Baltimore Sites. I have seen it more times active on QA and Talbot Sites. Might be used more with helos on the shore.
atlong
Jefferson County, WV
Hi all...I admit, I have not followed this thread in a while, but I have been tracking the MD FIRST system from the Lambs Knoll ASR in Washington County. I've been monitoring it for the past 30 days or so and have logged many undocumented TG's. Anyone want to take a stab at what they are? I have concatenated all the Pro96Com csv files into one spreadsheet and then filtered out the undocumented groups with their respective radio id's that have affiliated on them. Attached is the sheet saved to a PDF file. Thoughts?
  • MD First Unidentified TGs.pdf
u2brent
OAMPT
KRWDPAXKRS1
Here's my very rough interpretation of your TG list :geek:
SHA ? 7251
SHA ? 7252
SHA ? 7253
SHA ? 7258
SHA ? 7270
SHA ? 7273
SHA ? 7276
SHA ? 7281
MSP ? 7345
MSP ? 7346
MSP Tac? 7403
MSP Tac? 7418
DNR Northern Forestry 7538
DNR Burn Ops? 7540
MIEMSS ? 7629
MIEMSS ? 7631
MIEMSS ? 7654
MIEMSS ? 7655 Enc
MIEMSS ? 7656
MIEMSS ? 7659 Enc
MIEMSS ? 7660
MD Interop? 8104
DHMH ? 8179
DHMH ? 8180
DHMH ? 8191
DHMH ? 8192
DHMH ? 8194
DHMH Stockpile Distribution 8195
DHMH ? 8197
DHMH ? 8198
MD Aviation Tac? 8311 Enc
MD Interop? 8316 Enc
MD Interop? 8319
DNR ? State Park 8383
MD Federal? 8415
MD Federal? 8416
FIRST ? 8511
FIRST Radio Tech? 8516
Washington Co ? 13024
Washington Co ? 13141
Washington Co ? 13258
Washington Co ? 13593
Washington Co ? 13594
Washington Co Fire/EMS Dispatch (Patch of TG 13463) 13595
Washington Co Hagerstown PD (Patch of TG 13557)? 13596 Enc
Washington Co Highways? 13599
Washington Co Sheriff Patrol Division (Patch of TG 13428) 13600 Enc
motorcoachdoug
Silver Spring, MD
Ok everyone. If you could please post what set up you are using to monitor the MD 1st system i would grateful. Since the system is not here in Monkey County I do have a Yagi Antenna aimed at the Howard county antenna and am picking it up just fine..
maus92
The OP
Notes:
Washington County
13599 - MSP RIDs
13596 - MSP RIDs, RID 2124582 uses syscom 7640 TG
13594 - MSP RIDs
13593 - MSP RIDs
State
8516 - RID 2128491 is usually on this TG, but sometimes MSP, MD Tac 8, SYSCOM, MSP RID range, prob MSP radio tech
8511 - MSP RIDs, likely MSP radio tech
8319 - RIDs assoc w/ DPSCS prisoner transport
8316 - RIDs assoc w/ DPSCS prisoner transport
8311 - RID FIRST / MSP radio tech; usually on tg 7455
Feds
8416 - Fed RIDs closely spaced, likely a single agency, unid
8415 - Fed RIDs closely spaced, likely a single agency, unid
firebal
Baltimore, MD
Would that be these? HELICOPTER DISPATCH 44.74 MHz and HELICOPTER MEDICAL 47.66 MHz 
maus92
The OP
Yes. Helimed is 47.66
The reason for the poor audio is that the medic uses a portable subscriber to talk on FIRST when in the helicopter, with an earpiece and a handheld mic. Super kludgey.
