MCC 7500
slobonmycob
I feel sorry for your agency if you’re the support
Is there not any way to select multiple channels so they all come through the headset instead of the speakers?
studgeman
You have to go into the audio settings, and there you can see your choices. You will need to use elite admin and open up each resource and change its audio settings. There is no way to "select multiple" for selected resource.
xmo
Adding the resources to a multiselect group doesn't work for you?
slobonmycob
What you are describing is Multi-Select. Set up a multi-select group.
Your vendor should have left a copy of the operators handbook, if they didn't tell them to get you one. Basic stuff like this is addressed in the handbook.
Here's a link to a PDF copy though, it's a bit dated. http://www.brics.butlersheriff.org/wp-content/uploads/2009/04/mcc7500-dispatch-operator.pdf
THIS!!! I have access to the operator manual already I'm looking into this now will post back in a minute
studgeman
This issue with the multiselect group, is that to select it, you have to put it in editing mode. If the console operator isn't careful it can get really funky really quick. You can lock the editing in Admin. It's just really goofy.
Tech21
No, it's not. A multiselect group is created by selecting MSEL 1,2 or 3, clicking the edit button within the MSEL group and selecting the resources you want in there. The dispatcher or anybody else doesn't have to go into elite admin to do this whatsoever. Same way with creating a patch within the console.
studgeman
Tech21 you are 100% correct. If I am interpreting the original question correctly, the question is about having audio from multiple resources sent to the headset (assuming select audio). Creating an MSEL grouping does not inherently route the audio to "selected" You have to select the MSEL grouping for that to happen, and the only way to do that is to put it into editing mode in Elite. So if the dispatcher clicks on another resource without without first unclicking edit on the MSEL, it will add the resource into the MSEL. This is usually not intent. It can get wonky really fast if you are not careful how it is implemented.
