MCSO no reception
Lwolf1313
El Mirage, AZ . USA
I just turned on my scanner and don't here anything on the MCSO system. I assume they are switching to the new P25 system? I have a BCD325P2 and using Freescan to program. When I upload the P25 system to the scanner there are no talkgroups listed like the programming for MCSO Mot type2 programming. Is that because the groups are not known yet or do I have to manually put them in?
Lwolf1313
El Mirage, AZ . USA
If anyone has a Freescan file for MCSO sheriff , that would be helpful. I just started programming the P25 system and just seem to receive only the base unit.
CT
You can temporarily put the scanner in ID Search mode to see if it's working.
Hit the FN Button and push SCAN while scanning.
The display will say "ID Search."
Please post a link to the system you are trying to monitor.
cfsimmont
In the middle of nowhere
Yes MCSO is on the new P25 system, the talkgroups that have been identified are in the DB and you can import them using Freescan (I did it this morning). When importing make sure you select the Sheriff category or it wont import those talkgroups.
Lwolf1313
El Mirage, AZ . USA
I did select the sheriff in the right column but it still is not importing the talkgroups.
KB7MIB
Peoria, AZ.
The talkgroups seem to be site dependant. District 2 and 3 are on the White Tanks site. If you want to hear East districts, you need to be within range of a more eastern site. Try Thompson Peak.
John
Peoria
cfsimmont
I am hearing the NW, SW, and Central units. On the old system I could also hear Lakes, and the East units.
On the old system all of the talkgroups were on all 3 sites that the SO used (White Tanks, Thompson Peak, & The Court bldg). On the new system the talkgroups are probably site dependant like John mentioned, try using the Thompson Peak site for the East valley districts.
Lwolf1313
El Mirage, AZ . USA
It must be site dependent, just hearing west units and central. Tried putting the east sites in but I'm probably too far to receive. Next time I go to the east side I'll unlock those sites and see what happens.
eg153wftx
Mesa AZ
Anyone have a map of the districts? I would like to divide the sites up in favorite lists.
East/ Fountain Hills, QC,East Mesa ?
West/ ????
KB7MIB
Peoria, AZ.
District 1 is Southeast, except Queen Creek
District 2 is Southwest
District 3 is Northwest
District 4 is Northeast, except Fountain Hills
District 5 is the recreational lakes and the Salt and Verde Rivers
District 6 is Queen Creek
District 7 is Fountain Hills
District 8 is the Mountain parks (formerly Parks & Trails district, and before that they were the Maricopa County Park Police)
East-West is roughly separated by I-17.
North-South is roughly separated by Northern Ave.
The Phoenix simulcast seems to carry a mix of East (at least D1) and West (at least D2) districts. I would think that the North County simulcast would do so as well (D3 and D4?).
John
Peoria
KB7MIB
Peoria, AZ.
The Anthem/New River simulcast should also carry a mix of East-West districts.
John
Peoria
Ravenfalls
Yes, Anthem carries east, west & lakes & callbox. Thompson Pk active with Lakes & 700.
On old System Thompson Pk was a site that carried most groups, now its very quiet. Thompson main current use is backup high site. Most of the talkgroup stay within the main Simulcast sites: Phx Simulcast is hub & stretches out to other Simulcast which covers the most populated parts of Maricopa County.
Anthem Simulcast main site Mt Gillen
Phoenix Simulcast main site Shaw Butte
South Mt Simulcast
larrylock
What scanner are you using? I am using a RS PRo652, downloaded and transferred the db to the scanner and still have a brick. Any suggestions?
KB7MIB
Peoria, AZ.
A PRO-652 will not work with this system. The system is P25 Phase II, and your scanner cannot receive P25 Phase II.
John
Peoria
