Motorola XPR 7550 vs Hytera PD782
N4KVE
PALM BEACH, FLORIDA
I think the only real thing that drives me crazy about Hytera's portables are that most of them feature the antenna centered on the radio (it's just weird and against 60+ years of communications standards).
Yeah, it took 3 minutes to get over the antenna in the center of the radio. I'm not using the factory "stubby" antenna. Rather, a Hytera 6" UHF non GPS antenna that's used on other radios they sell. But I have the Harris HDP150, & the Hytera PD782, & I prefer the taller knobs on the Harris.
http://www.hytera.us/Download/Private/Image/Items/AN0465W01.png
RayAir
AES requires a feature control update license and runs about $270 per radio. Chose the DMRA Full Encrypt version, not Hytera Full Encrypt (unless you happen to want it). DMRA is compatible with MotoTRBO AES.
PM me if you don't have a dealer to go through.
Hytera antenna- The look of the antenna in the middle was the only hang up I had on trying their radios. They claim it is for increased reception.
n1das
Nashua, NH
The location seemed a little weird at first but I found I quickly forget it's in the middle instead of being off to one side. It actually makes sense because the volume and channel knobs are moved to the corners for easier access.
I think the mods should create a Hytera forum so we can discuss all things Hytera like all things Motorola discussed here.
IAmSixNine
Dallas, TX
Im about to start "scanning" some DMR near me and i have many different options of radios to chose from. It looks like the number 1 question was answered in the first post as to which radios scans connect plus systems best and thats they Hytera PD782 with the pseudo trunk option. BUT does that also relate to all Hytera radios? PD362 and PD682 and X1p? I ask because the others look to be cheaper.
Further more do other radios have a similar capability to scan connect plus systems?
CS750 and TYT Tytera MD-380 and MD-390 are also radios ive read online and have been mentioned but not sure if they will scan like i want them to.
Ive also read that its easy to program in the frequency as single channel and use the color code and slot to scan the talk groups. So instead of proper trunking your still scanning the channels more like a conventional system. Or am i way off on that? Anybody have experience with the Vertex EVX-534 while were on the subject?
IMPRES2
You program custom tones in User Defined Tone under Common in the CPS.
I recorded and analyzed a NEXTEL chirp some time ago and was able to determine tone and duration. For NEXTEL phones, the tone was around 1800Hz. The Motorola TPT is around 910 or 920Hz. The tone durations appear to be the same. The Moto TPT at 910Hz is effective as a TPT but less obnoxious than the old NEXTEL DirectConnect chirp.
30ms 910Hz
20ms 0Hz (silence)
30ms 910Hz
20ms 0Hz
50ms 910Hz
Note that the 3rd tone is slightly longer than the first 2 tones.
Has anyone found a way to get the XPR 7550 radios to do this?
TonyS
NJ, USA
I'm wondering if the receive performance has gotten better with recent firmware upgrades for the Hytera PD782. Anyone notice any improvement or change? I'm debating between the XPR7550 and the PD782 but the Mot CPS and the wideband key is definitely a factor in the equation.
N4KVE
PALM BEACH, FLORIDA
My 782 has recent FW, & the Rx sens is as good as a XPR6550. But the XPR7550 has better Rx sens than any UHF radio I have ever seen.
TonyS
NJ, USA
I figured that might still be the case but ya never know. Thank you.
N4KVE
PALM BEACH, FLORIDA
If the owner's eyesight isn't as good as it used to be, the display font on the 7550 is much bolder than on the Hytera. But I own both, & keep the Hytera because of the FPP function.
